Cisco UCM and Unity Connection Compatibility Issue (matrix)?
MehmetKaya
Cisco Call Manager Version : 8.6.2.20000-2  (Locale Installer : cm-locale-tr_TR-8.6.2.1000-1.cop )
Cisco Unity Connection : 8.5.1.11900-21 (Locale Installer : uc-locale-tr_TR-8.5.1.1-16.cop)
This systems works together. We will upgrade Cisco CallManager(CUCM) to 8.6.2.21900-2 with cm-locale-tr_TR-8.6.2.1000-1.cop )
Cisco callmanager 8.6.2.21900-2 will be compatible with Cisco unity connection 8.5.1.11900-21 ?
Is there any decumantation to check this ?
Thanks.
Docs do not go to that detail, they just mention major versions and anything within that version is supported.
EDIT:
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use  with any version of Cisco Unified CM 4.1(3) or later.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
Yes, if you search CSC for the same topic you can find previous threads with the link.
SCCP Compatibility  Matrix: Cisco Unity  Connection, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
java
java
Thanks for your quick response. I have found that doc. But from this doc. I am not able to see detailed version.
For example 8.6.2.21900-5 ?
Is there any doc. to show detailed information.
EDIT:
java
java
Thanks.
It means that Cisco Unity Connection "8.5.1.11900-21" release will works with all Cisco UCM release 8.x .
