Cisco Unified Attendant Console 10.5 Standard
CiscoRunner
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-attendant-console-standard/datasheet-c78-731866.html
Hello Folks,
I am looking for further info regarding the below product from Cisco. I have some experience with ARC Attendant console so I understand how this all works. I think ARC is a bit overkill for what we need so hence I am looking at the below product. Key point being that the software runs locally on the receptionists machine.
One question, we have one site that is split across 3 separate buildings, with each building having a receptionist. Is it possible to have all 3 receptionists login and receive calls to just a single extension? i.e. any of the 3 of them could answer the inbound call?
Jaime Valencia
If you configure them as shared line or in a line group with broadcast, yes.
java
if this helps, please rate
