Unity Connection Service status is DOWN. Connection Database Proxy. The alert is generated on Mon Jul 22 13:17:42 EDT 2013 on node Unity Connection 7let me know what will be the issue
Does anyone know about how to use "speed dial service" in Israel?Speed dial serivce is like an abbrevation number which has *XXXX(star and 4 digits).It is used by companies to make it easy for customer to contact them.I would like to use Speed dial s...
Cisco 7970 Phone not booting after Factory ResetI followed the below mentioned Factory reset method1) power off the phone (if using inline power, just remove the ethernet) 2) hold the hash (#) button down 3) supply power to the phone (if inline pow...
hi alli have attached CCSIP messages with it call Flow: ISP SIP Trunk---------->CUBE-SIP Trunk---------->CUCMi am new in SIP configuration with cube and Service Provider, First Issue: we have a DID complete number 364909XX and i have configured my ip...
Dear Guys, Suggest the upgrade path for below requirements,,,,,as we know UCS C200 is obsolete....should i need to replace the hardware?when i review the compatibility matrix h/w supported...How can i do a upgrade ,,,,what are the application need to...
Hi Experts ,i have at HQ CUCM with publisher and one subdcraper , and i have new office branch which can accommodate up to 1700 employees with ip phone for for each employee and that branch connected with HQ through wan what is the best solutions ...
hi Team,I am currently stuck with overlapping rules in a translation-rule, below are 3 rules which I have configured.In CME, I have configured translation profile under ephone-dn-template, which is then assigned to ephone-dn's. So as soon as any DN d...
Dears,Attached is the sh run and debug ccsip messages from the CME router, I am not able to dial outside to PSTN nor incoming calls. Please help to get success.Questions:how I will know how many digits I shld send towards ITSP and how many digits I s...
Hi. calling number is 043162467 called to 2041111 > translation pattern converting to > 1511000 please let me know if can one could help for solving the issue. 12/15/2014 16:22:47.140 CCM|Forwarding - processFwdLoopPrevention - mFwdToTable[1511000:...
Hello,Can I modify Ringlist.xml only one phone?I want add a ringtone but I want appear in only one phone. It's possible? Best regards
Hi, what does I need for use a Cisco 7925G with a SIP Server?RegardsMario
So when a user tried to get into voice mail by pressing the messages button on the phone, only to find out that they are locked out and they are automatically transferred to an ext. I would imagine there is a call handler doing this but I could be wr...
Hi Everyone, Topology: Remote Site = H323 = CUCM = SIP Trunk = CUBE = SIP = Service provider.Scenario: SP require Early Offer with OOB DTMF.I have checked early offer on SIP profile, with "insert MTP if required".On CUCM SIP trunk i have set the DTMF...
Hi EveryoneI am having Cisco 2901 router with FXO card and 2 PSTN lines terminating on it, Now the problem is i also want to do SRST on it and register the phonesSo i wanted to know the approach how tro go about it , SRST should i put SIP SRST comman...
Hi, I am using Cisco Unity Express on 2921 router with SRM, It has already license of 30 voicemail boxes. Now I want to install a license of 5 voicemail boxes. When I try install the new license, I got an error saying that a better license curren...
Subject | Author | Posted |
07-23-2025 12:10 PM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
11 | |
2 | |
2 | |
1 | |
1 |
