cisco unified communication manager bussiness edition 8.0 redundancy
AhmedBassiony
Hello, I need to perform CUCMBE redundancy, is this available in CUCMBE 8.0 or not?
and if Yes, what the product number which can i use?
Thx
Joseph Martini
You can use Survivable Remote Site Telephony (SRST) for redundancy with Call Manager Business Edition.
Jaime Valencia
If you mean you want another server in a PUB-SUB fashion the answer is no.
CUCMBE is a single server solution.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
