cisco unity connection 11.5 fax to email
brianbeck86029
We are using Unity Connection & CUCM 11.5. We have some ATA FAX lines that we would like to convert to FAX to email. Is this possible without having to use a separate FAX server application?
Jaime Valencia
No, there used to be an option called Cisco Fax Server which integrated with CUC for that, but as you can see in the guides, it's EOS/EOL
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/administration/guide/b_cucsag/b_cucsag_chapter_01111.html
Newer guides only contain the option for 3rd party fax servers
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/12x/design/guide/b_12xcucdg/b_12xcucdg_chapter_01110.html
java
if this helps, please rate
Jaime Valencia
java
