IP Telephony and Phones
Labels
I have a DID number range from a phone company 562-123-7512 - 7579  I would like to use 6 digit rule for inbound calls so it will match the last 2 digit but it is not working when tested.  Rule 1:Match pattern: ^56212375\(..\)Replace pattern: \1Match...
BigK by Level 1
  • 1553 Views
  • 7 replies
Is the "Dial Plan" configuration mandatory with ATA 192?  Based on my past experience, dial plan is usually controlled on PBX side.  Why do I have to configure "dial plan" on end points (i.e. ATA 192)? If I HAVE TO configure dial plan on ATA 192, I'd...
helloguys by Level 1
  • 773 Views
  • 1 replies
We recently upgraded from EX90s to DX80s.  The problem we discovered is, with the EX90 we bought headset & mic's that used 3.5mm jacks.  Unfortunately, there are no 3.5mm ports on the DX80, only USB.  Is there a USB-to-3.5mm converter that can be use...
Hello Team, I have requirement, where the customer has Cisco 2901 VG router and now he want to upgrade his PRI to SIP.I know we can use basic Cube functionality  without  enabling  RTU cube license.. Just want to understand.. how risky it would be.. ...
HelloI need to upgrade our CME 8.6 to higher version. I got Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(4)M8 , RELEASE SOFTWARE (fc2).At main site CME, I need it to setup 2 SIP accounts using DN overlap and in previous...
Hi AllI have a Cisco CUCM 10.5.1 and integration between CUCM and CUC for Voicemail is Ok. Cisco documents said that "A voicemail profile is assigned to a directory number, not to a device". when I added voicemail profile to one device with shared li...
s.maxina1 by Level 1
  • 857 Views
  • 2 replies
Hello,I want to change Diversion header from: 6090........ to: 02123766100 This is my rule:voice class sip-profiles 100request INVITE sip-header Diversion modify "<sip:6090........@>" "<sip:02123766100@>" I also added this profile under dial peer:dia...
ailhan001 by Level 1
  • 3110 Views
  • 3 replies
