Cisco Unity Connection Messaging filling up Voicemail mailbox
bjorn.tegelberg
About once every minute a new entry is created, which fills up the Voicemail mail (10,000+ entries!)
Subject: Message from Unknown sender (Unknown caller ID)
Duration: about 19 secs
Message: If you want to turn off message notification to this number press 1 now.
Hello this is the Cisco Unity Connection Messaging system with a message for MAILBOX NAME. To check new messages enter your PIN now. If you want to turn off message notification to this number press 1 now.
Anyone experienced similar? What would be the best way to make sure this message is now sent to the Voicemail mailbox?
(There are some actual Voicemail messages as well, so the Voicemail for the extension works)
bjorn.tegelberg
Turning off 'Notification Devices' - 'Work Phone' solved the issue.
Have you tried to schedule a reboot for the server.
bjorn.tegelberg
