Cisco Voice Gateway Multi Tenant Two Different PSTN breakouts
Sauron
HI Guys
need some advise I have and client that has an existing infrastructure, with 2  voice gateways connecting via h323 to an Call Manager, each VG has one PRI towards the PSTN
This client will be will get a tenant in their premises that will use the same telephony infrastructure but will have an SIP connection to their own sip provider.
My question is how does one go about ensuring only  calls coming from the tenant  on the  same VG's where my client's PRI connects to gets send from the VG's to the sip provider only. It must not go over the PRI. Any ideas will be appreciated
Jaime Valencia
Configure separate RPs for each tenant and add a fixed prefix to differentiate the calls, on the VGW, configure the dial peers to match those prefix and route as required.
java
if this helps, please rate
Jaime Valencia
java
Thank you. I will try this out and let you know
