We are running CallManager 7.1(5) and the Administration page will not load. I tried to restart the Tomcat service but had not luck. I went to the console and it is scrolling the following message:
ext3-fs error (device sda6) in start_transaction: Journal has aborted
When I sign on to the console I am presented the following error msgs:
Please use Recovery disk to check file system using fsck
and
log4j: Error no output stream or file set for the appender name (CLI_LOG)
I am downloading the most recent Recovery Disk from Cisco.com but before I start rebooting or start the recovery process I wanted to see if anyone has come across this and if so what did you do to fix the issue?
TIA
Jake
