CM Trunk to Gatekeeper
m.cucchi
I guys ...
I have a technical question about trunk to gatekeeper.
CallManager version 5.1.3
Gatekeeper Cisco version 12.4
On the gatekeeper I have registered 2 trunks from a call manager.
During a network problem in between callmanager and gatekeeper the trunk are deregistered.
The problem is that these trunks do not register anymore on the gatekeeper.
Someone knows the timer that the call manager has on the trunk H323 (h225 gatekeeper controlled).
Es. How many time the call manager try to register on the gatekeeper, and after consider the gatekeeper unreachable ?
The call manager stop to register on the gatekeeper or try sometime after minutes/hours ?
Thank you
Massimo
gogasca
Level 10
Level 10
Check CUCM options under Gatekeeper configuration...
Registration Request Time to Live
Registration Retry Timeout
