Assuming you keep the same AD attribute as userID and they don't change, you shouldn't have any problem.
CUCM really doesn't care about schema updates as it only syncs specific fields and don't look into anything else (at least not until 9.X where you can configure extra fields to sync)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
