CME 10.5 phonepassword in XML file
critchey880
I have some 7841 phones that at first have no admin password needed.  I am defaulting the phone, letting it connect to our system, and after it does so it needs an admin password Cisco. I can see in the XML that it is listed under phonepassword as Cisco.  Is there a setting in CME that I can change to not need or blank the admin password? Or am I stuck manually editing every XML file manually to remove it(if that even works, have not tried it)?
Removal of password by using TCL script will work. I have tested it in my lab earlier and it does work.
You can also follow this non cisco link
https://collabengineer.com/2014/11/15/cisco-sip-phones-admin-password-removal-cme-tclsh-operation/
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Any chance you can post an example of your TCL script?
