CME 12.0 Internal Call betwin ip endpoint not work "Reason: Q.850;cause=17"
ycaraballo
Feb 12 21:41:27.660: //1353/C94EF83D8A4E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 486 Busy here
Via: SIP/2.0/UDP 172.17.20.26:5060;branch=z9hG4bK6cd203d1
From: "IPPhone-5533" <sip:5533@172.17.20.1>;tag=0cd0f8f4f62c00090967c61c-011f72d3
To: <sip:5539@172.17.20.1>;tag=1A148884-8B3
Date: Tue, 12 Feb 2019 21:41:27 GMT
Call-ID: 0cd0f8f4-f62c0005-3107c562-15db3537@172.17.20.26
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.7.3.M3
Session-ID: 09b1933700105000a0000cd0f8f4f62c;remote=a20bfafddba65ae7bf089340692577ac
Content-Length: 0
ycaraballo
Someone help?
cause value 17 means user is busy. Can you check if you have phones
registered to CME (show voice register poo all brief). Also, are you
limiting the number of channels on the DNs using max-calls or busy-trigger.
HARIS_HUSSAIN
I had similar issue , I was facing below bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb75834/?rfs=iqvred
What is your IOS version. Try Upgrading your IOS Version, that will resolve the issue.
Haris
*** Please rate helpful post and Mark Solution accepted if issue is resolved.
