CME 2821 "File Not Found XMLDEFAULT
MohamedHussen
Hi Team
I am getting "File Not Found XMLDEFAULT"error message on my home lab, 1st time set up, my config on the router is as below, pls help, what am I missing? the cisco 7940 phone is attached to switch 1, the phone gets the correct ip address then the tfp i believe is the issue.
SIT2620B#sh flash:
-#- --length-- -----date/time------ path
1     51054864 Jan 21 2009 20:33:28 +00:00 c2800nm-advipservicesk9-mz.124-15.T3.bin
2       129356 Aug 8 2016 12:48:38 +00:00 P00307000200.bin
3          461 Aug 8 2016 12:49:10 +00:00 P00307000200.loads
4       668424 Aug 8 2016 12:49:40 +00:00 P00307000200.sb2
5       129760 Aug 8 2016 12:50:04 +00:00 P00307000200.sbn
6            0 Aug 14 2016 10:51:46 +00:00 its
SIT2620B#sh run
Building configuration...
Current configuration : 3672 bytes
version 12.4
hostname SIT2620B
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.100.1 172.16.100.10
ip dhcp excluded-address 172.16.200.1 172.16.200.10
ip dhcp pool Voice
   network 172.16.100.0 255.255.255.0
   option 150 ip 172.16.100.1
   default-router 172.16.100.1
ip dhcp pool Data
   network 172.16.200.0 255.255.255.0
   default-router 172.16.200.5
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
 no dspfarm
crypto pki trustpoint TP-self-signed-2670313565
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2670313565
 revocation-check none
 rsakeypair TP-self-signed-2670313565
archive
 log config
  hidekeys
interface GigabitEthernet0/0 <<<<<<<< to switch
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.100
 description voice vlan
 encapsulation dot1Q 100
 ip address 172.16.100.1 255.255.255.0
interface GigabitEthernet0/0.200
 description data
 encapsulation dot1Q 200
 ip address 172.16.200.1 255.255.255.0
interface GigabitEthernet0/1
 description tft
 ip address 172.16.2.200 255.255.255.0
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:
tftp-server flash:P00307000200.bin alias P00307000200.bin
tftp-server flash:P00307000200.loads alias P00307000200.loads
tftp-server flash:P00307000200.sb2 alias P00307000200.sb2
tftp-server flash:P00307000200.sbn alias P00307000200.sbn
control-plane
telephony-service
 load 7960-7940 P00307000200
 max-ephones 5
 max-dn 5
 ip source-address 172.16.100.1 port 2000
 cnf-file location flash:
 cnf-file perphone
 max-conferences 8 gain -6
 transfer-system full-consult
ephone-dn  1
 number 1001
 name Sahan Office
ephone  1
 device-security-mode none
 mac-address 000D.29D8.1F35
 button  1:1
line con 0
line aux 0
line vty 0 4
 password cisco123
 login
scheduler allocate 20000 1000
end
Under you ephone 1 put the command 'type 7940'
Thank you Bro, worked 🙂
