CME 8.1 with B-ACD (3.0.0.2) transfer problem/support
etmarcof
Level 3
Level 3
I have one CME 8.1 ( router 2921 - IOS:c2900-universalk9-mz.SPA.151-2.T2.bin)  connected to PSTN  through BRI interfaces.
When i receive an incoming call from PSTN call goes to  AA (B-ACD 3.0.0.2) > welcome message >  One of the extension  in ACD group  answer call > sometimes the user that answer the call needs to transfer (blind) the call to another extension and problem happens.
When this final extenstion is busy or  no answer  the call is forwarded to  another AA (B-ACD 3.0.0.2) and its dropped , i.e  user that makes the transfer starts hearing the AA welcome message but as soon as press transfer button external call is dropped. I have tested same cenario  with consult transfer ( not blind ) and worked.
Calls coming from one AA answered by one extension and then  transfered to another AA aren't supported ?
in my config i have
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
telephony-service
transfer-system full-consult dss
transfer-pattern .T
Any suggestions?
Best Regards,
MC
yuanwu
Hi, MC
1. Did the same call flow work if the final extension answered the call with blind transfer?
2. Did the normal call without involving AA work fine? just like dial one extension from another extension and CFNA or CFB to AA or VM ?
Rgds/Randy
Thanks for your help but I have already  solved my problem adding these two commands to voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
The problem only happens  with calls that originally begins in one AA and are answered by one extension that  answers the call aand then transfers that to a final extension that forward call because is busy or not answer to another  AA.
Best Regards
MC
Hi, MC
nice to know that the issue was fixed.
Rgds/Randy
