cme 8.5 sip sccp dialing
miket
Level 5
Level 5
I have a 8961 and 7962 sip phones registered to a cme I also use SCCP phones. I have two fxo trunks for pstn dialing. I cannot get the sip phones to dial anything.. Any help or a sample config would help
cadet alain
can you post sh run please.
Regards.
Alain.
i  will attach the sh riun  i did get the outboind dialing working but i cant dial the sccp phones  i maybe missing a voip dial peer  the problem wa my sip phones had the same extensions as a sccp phone  i thought you can have the same extension appear on a sip and sccp  you can with callmanger
so soon as i can i will attach sh run
can you share extensions in cme?   even though soon as i changed extension numbers outbound dialing worked
