How can i access ATA using web browser..?
midhun_km
As like Ip phone
http://<ip add of phone>................
is there any possible way to open the ATA 186 registerd with call manager....?
urgent Plz help me.......
6 Replies 6
Jaime Valencia
From the PC, open a Web browser and enter this  URL: http:///dev.
http://www.cisco.com/en/US/partner/products/hw/gatecont/ps514/products_configuration_example09186a00800c3a50.shtml
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi java ..
Thanks Dude................
Exactly what i want is this.....
Hi Java,
I'm facing some problem with switch ports conneted to ATA.
from the switch log window its contunuslly showing the message
2011-03-07 10:28:5523410.40.6.207*Mar 10 19:40:40: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/39 (not half duplex), with SEP0026CBBE8C61 Port 1 (half duplex).
2011-03-07 10:28:5323410.40.8.234.Mar 6 20:52:25: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/25 (not half duplex), with SEP64168D51BAD2 Port 1 (half duplex).
2011-03-07 10:28:3123410.40.8.233.Mar 7 04:30:32: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/11 (not half duplex), with SEP0026CBBE8C63 Port 1 (half duplex).
Whenever  i compare the  ATA conneted with one the switch ports above shown with another perfectly working ATA's using http:///dev
inside the both ATA's webpage showing the same denominations for all the attibutes.
I changed the duplex of each switch port to half duplex then the switch log window message is get inverted. like.......
011-03-07 10:28:5523410.40.6.207*Mar 10 19:40:40: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/39 (not full duplex), with SEP0026CBBE8C61 Port 1 (full duplex).
2011-03-07 10:28:5323410.40.8.234.Mar 6 20:52:25: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/25 (not full duplex), with SEP64168D51BAD2 Port 1 (full duplex).
2011-03-07 10:28:3123410.40.8.233.Mar 7 04:30:32: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/11 (not full duplex), with SEP0026CBBE8C63 Port 1 (full duplex).
so the also tried with duplex auto, message is same...
and also i try with all the 9 combinations ..................
duplex auto . speed auto,100,10
duplex half. speed auto,100,10
duplex full . speed auto,100,10
So how can i resolve the problem...?
HI Midhun,
Did you tried a shut and no shut after making the duplex changes in the ports .
Hi Midhun,
The %CDP-4-DUPLEX_MISMATCH messages may be generated repeatedly when Cisco Discovery Protocol (CDP) has discovered a mismatch of duplex configuration between CDP neighbors.
This message occurs when a duplex mismatch is detected between CDP neighbors. It can also occur when switches are separated by a non-Cisco switch or hub. If CDP version 2 reports the link as a half-duplex when a port or interface on a CDP-enabled device has been configured or auto negotiated to full-duplex, the alternate device may not support CDP version 2. This causes the error to occur. It is a cosmetic issue.
CDP is useful for detecting errors as well as port and system statistics on neighboring Cisco devices. CDP is Cisco proprietary and works be sending packets to a well-known MAC address 01-00-0C-CC-CC-CC.
To resolve this issue, perform these steps:
  1. To disable CDP version 2, issue the no cdp advertise-v2 command.
  2. To check the CDP version running on the device, issue the show cdp command.
