CME 9.1 and converting SCCP 6945 to SIP 6945 ?
Jason Aarons
Level 6
Level 6
I have a customer with SCCP 6945s registered to CallManager Express 9.1.  I want to convert the 6945s from SCCP to SIP (to match some SIP only 8971s).
How do I get these 6945s to switch from SCCP to SIP?
5 Replies 5
acampbell
Jason,
Have a look in the CME Admin Guide.
Section SCCP: Converting Phone Firmware to SIP
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1065072
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
The Admin Guide didn't work.  Seems to be more focused on 79xx phones.  I also tried a factory reset on 6945, debug attached of phone booting, and a show run.
Jason,
Looks like phone is still able to retrieve it config file
From your TFTP trace
Apr  9 15:04:53.110: TFTP: Looking for SEP8875567AF7FF.cnf.xml
Apr  9 15:04:53.110: TFTP: Opened flash:/its/SEP8875567AF7FF.cnf.xml, fd 4, size 4218 for process 15
Apr  9 15:04:53.110: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x2E751AF8
Apr  9 15:04:53.112: TFTP: Received ACK for block 1, socket_id 0x2E751AF8
Apr  9 15:04:53.112: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x2E751AF8
etc etc etc
Can you confirm that you have deleted the SCCP ephone
no ephone xx
Then can you try to delete the cnf file
telephony-service
no create cnf-files
Now try resetting the phone by re-inserting the cat5 lead
See how this goes
Alex.
Spent 2 hours with case TAC 625498511 and they couldn't get a 6945 SCCP to switch to SIP using Express.  I finally used a CallManager to get it to switch to SIP.  Then the SIP 6945 couldn't register to CME, we spent 2 hours troubleshoting/debuging/tracing and gave up.  I went back to SCCP 6945.  Then I hit several SCCP 6945 CME 9.1 bugs like DND doesn't update on display, dtmf not working wo Unity Express 8.6, etc.
I'm thinking the 6945 wasn't a good choice.
Hi Jason
Sometimes you just wonder if you would be better with
2 cans and a tight string
Up the 7960
Alex.
