03-01-2010 11:55 AM - edited 03-15-2019 09:35 PM
I am running CME 7.0 and configured extension mobility. After entering the username and PIN for EM login, the screen hangs dispaying "logging in". Pressing the exit softkeys shows that the user profile has been loaded succesfully. The issue is encounted during the logout process. Th screen just hangs, but pressing exit displays the correct screen. Any ideas what may be causing this? I'm runing IOS 12.4(20T) and 7941 phones.
03-01-2010 01:28 PM
I found this bug:
CSCsx66104
CME EM login,logout behavior abnormal, requires exit key to press 3 time
Also some users upgraded to 12.4(22) YB1 and that apparently helped.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-23-2011 11:47 PM
I have the same problem with my CME 7.1 running on ios Version 15.0(1)M4. The screen hangs in loggin in and logging out. Is there any workaround found for this ?
05-24-2011 07:16 AM
I upgraded the ios to 15.01M(5). But still the same. Any help would be much appreciated.
11-23-2011 05:52 AM
I am also facing the same issue ...... i am running CME 8.0. and the IOS version is uc500-advipservicesk9-mz.150-1.XA2.bin
Can anyone help me on this ... Thanx in advance.
