10-13-2011 03:54 PM - edited 03-16-2019 07:30 AM
Hi guys, i need some help to change the ani that the PSTN carrier is recieving from the cme.
The PSTN Carrier is recieving the extension ID that is 7xxx from the cme, the problem is that he is specting to recieve 23987xxx, so i have to add this 2398 to the ani. Is it posible?
Can i do it with the command:
clid network-number 23987xxx
on the designated pots.
dial-peer voice 6009 pots
destination-pattern [09]9......
port 0/0/0:15
forward-digits 7
Carlos Cánepa
Solved! Go to Solution.
10-13-2011 04:45 PM
Carlos,
If you aad this config it should do what you need.
You may want to change the rule number or the profile name to suit you.Mine are
only suggestions.
voice translation-rule 7
rule 1 /7/ /23987/
voice translation-profile OUTBOUND-CLI
translate calling 7
voice-port 0/0/0:15
translation-profile outgoing OUTBOUND-CLI
Alex
10-13-2011 04:45 PM
Carlos,
only suggestions.
rule 1 /7/ /23987/
translate calling 7
voice-port 0/0/0:15
Alex
10-14-2011 06:25 AM
Many Thanks
Works
Regards.
Carlos Cánepa
