CME call-forward no answer on the phone
alig.norbert
Level 4
Level 4
Hi there,
We have a CME (Version 7.1) and I would like to change the "call-forward noan" number through the phone...so that the user can decide,
to with number the call should be forwarded. Only 2 numbers are used.
Has someone a clue, or do I need to do a script on the workstation?
Norbert
kaja_2kj3
    It cannot be changed from the phone, It has to be done through the script, It looks there is some on this link,
http://ciscoscripts.com
Please rate if this helps
kaja_2kj3
Thank you Kaja for pointing to my work.
I need to clarify that this script (that is quite complex) is not finished and will be only developed on a business contigency basis.
