CME call forwarding to wrong number
Michael Murray
Level 2
Level 2
I'm running a CME 7.0(0) and am having a weird issue with call forwarding. When I configure a ephone-dn with "call-forward all" the call does not go to the intended number. Instead it is going to one of our users' cell phones.
Example
ephone-dn 6 dual-line
number 5761
call-forward all 18885551212
And any time someone calls extension 5761 the call is sent to another users' cell phone instead of the 888 number above. The ISDN q931 debug is below and shows the correct called party number (18885551212) but it also looks like the call gets disconnected within a few seconds. On the phone I hear the call ringing for a while then the wrong user's cell phone answers.
When I remove the "call-forward all" config the number just goes to the extension per normal.
Feb 18 17:17:24.543: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0402
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Facility i = 0x9F8B0100A115020101020100800D54414C414C4153204E4F4C594E
                Protocol Profile =  Networking Extensions
                0xA115020101020100800D54414C414C4153204E4F4C594E
                Component = Invoke component
                        Invoke Id = 1
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = JOHN SMITH
        Calling Party Number i = 0x0080, '6175550072'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '5761'
Feb 18 17:17:24.543: ISDN Se0/2/0:23 Q931: Received SETUP  callref = 0x8402 callID = 0x0402 switch = primary-ni interface = User
Feb 18 17:17:24.555: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8402
        Channel ID i = 0xA98381
                Exclusive, Channel 1
Feb 18 17:17:24.563: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 16175550072
Feb 18 17:17:24.563: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x0986 callID = 0x8907 switch = primary-ni interface = User
Feb 18 17:17:24.563: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0986
                Standard = CCITT
        Channel ID i = 0xA98386
                Exclusive, Channel 6
                        Invoke Id = 1
                                Name = JOHN SMITH
        Calling Party Number i = 0x0080, '16175550072'
        Called Party Number i = 0x80, '18885551212'
        Redirecting Number i = 0x00008F, '5761'
Feb 18 17:17:24.595: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8986
Feb 18 17:17:24.615: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8986
        Cause i = 0x8281 - Unallocated/unassigned number
Feb 18 17:17:24.619: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0986
Feb 18 17:17:24.635: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8986
Feb 18 17:17:25.939: %SCHED-2-EDISMSCRIT: Critical/high priority process VTSP may not dismiss. -Process= "VTSP", ipl= 0, pid= 236,  -Traceback= 0x80E7FA3C 0x820AFC6C 0x80E67DA0 0x80E99178 0x80E96F44 0x80E98C98 0x8214D4E4 0x8214D744 0x8214DAF4 0x821447E8 0x821477F0 0x80B53834 0x8085C8FC 0x80864DD0 0x82DD1F80 0x82DD26E8
Feb 18 17:17:28.547: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8402
        Cause i = 0x80A2 - No circuit/channel available
Feb 18 17:17:28.575: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0402
Feb 18 17:17:28.579: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8402
6 Replies 6
Chris Deren
You missed the debug. Also, provide "debug voice dialpeer"
Updated original post with the ISDN debug. "debug voice dialpeer" below:
Feb 18 17:40:09.895: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
Feb 18 17:40:09.895: //-1/04DA56BF842B/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:14.304: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0403
Standard = CCITT
Invoke Id = 1
Name = JOHN SMITH
Feb 18 17:40:14.304: ISDN Se0/2/0:23 Q931: Received SETUP  callref = 0x8403 callID = 0x0403 switch = primary-ni interface = User
Feb 18 17:40:14.304: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6175550072, Called Number=5761, Voice-Interface=0x86A03F04,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=10
   Calling Number=6175550072, Called Number=5761, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
Feb 18 17:40:14.304: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=5761, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=5761
Feb 18 17:40:14.308: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
Feb 18 17:40:14.308: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20003
Feb 18 17:40:14.312: //-1/077AFA2F8404/DPM/dpMatchPeersCore:
Feb 18 17:40:14.312: //-1/077AFA2F8404/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 18 17:40:14.312: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=5761, Called Number=5761, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 18 17:40:14.312: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=, Called Number=18885551212, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=18885551212
Feb 18 17:40:14.316: //-1/077AFA2F8404/DPM/dpMatchPeersCore:
Feb 18 17:40:14.316: //-1/077AFA2F8404/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=12
Feb 18 17:40:14.316: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=18885551212, Called Number=18885551212, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 18 17:40:14.316: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=12
Feb 18 17:40:14.316: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=18885551212, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=12
Feb 18 17:40:14.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=16175550072, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=16175550072
Feb 18 17:40:14.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=12
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=12
Feb 18 17:40:14.320: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8403
Feb 18 17:40:14.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 18 17:40:14.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Feb 18 17:40:14.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=12
Feb 18 17:40:14.324: //-1/077E06F78430/DPM/dpMatchPeersCore:
Feb 18 17:40:14.324: //-1/077E06F78430/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=12
Feb 18 17:40:14.328: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 16175550072
Feb 18 17:40:14.328: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x0987 callID = 0x8908 switch = primary-ni interface = User
Feb 18 17:40:14.328: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0987
Standard = CCITT
Invoke Id = 1
Name = JOHN SMITH
Feb 18 17:40:14.348: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8987
Feb 18 17:40:14.368: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8987
Feb 18 17:40:14.372: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0987
Feb 18 17:40:14.392: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8987
Feb 18 17:40:14.396: %SCHED-2-EDISMSCRIT: Critical/high priority process VTSP may not dismiss. -Process= "VTSP", ipl= 0, pid= 236,  -Traceback= 0x80E7FA3C 0x820AFC6C 0x80E67DA0 0x80E99178 0x80E97B90 0x80E98C98 0x8214D4E4 0x8214D744 0x8214DAF4 0x821447E8 0x821477F0 0x80B53834 0x8085C8FC 0x80864DD0 0x82DD1F80 0x82DD26E8
Feb 18 17:40:14.896: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:14.900: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:14.900: //-1/07D54DCE8434/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:19.896: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:19.896: //-1/0AD044DC8435/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:20.308: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x0403
Cause i = 0x8290 - Normal call clearing
Feb 18 17:40:20.312: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x8403
Feb 18 17:40:20.328: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0403
Feb 18 17:40:24.904: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:24.904: //-1/0DCC73A28436/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:29.888: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 18 17:40:29.888: //-1/10C4F9788437/DPM/dpAssociateIncomingPeerCore:
What is really odd too is that, while the debug above says "Unallocated/unassigned number" and there is a disconnect from the PSTN
"Feb 18 17:40:14.368: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8987 "
I continue to hear my phone ringing after the disconnect and the call connects with a user's cell phone. I do not see the user's cell phone digits in any of the debugs nor the configuration. I'm stumped.
Chris Deren
Call is not matching anything:
"Cause i = 0x8281 - Unallocated/unassigned number"
Can you post your full config?
Thanks for looking at this. Config below:
Building configuration...
Current configuration : 34163 bytes
! Last configuration change at 12:53:40 EASTERN Wed Feb 18 2015 by admin
! NVRAM config last updated at 12:55:25 EASTERN Wed Feb 18 2015 by admin
version 12.4
parser config cache interface
no service pad
service internal
service compress-config
hostname UC520
boot-start-marker
boot-end-marker
card type t1 0 2
logging message-counter syslog
logging buffered 10000
enable secret 5 $1$lqcz$B9fhRM/4qjD./I6GxLrKn1
no aaa new-model
clock timezone EASTERN -5
clock summer-time EDT recurring
clock calendar-valid
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
crypto pki trustpoint TP-self-signed-1437432314
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1437432314
 revocation-check none
 rsakeypair TP-self-signed-1437432314
crypto pki certificate chain TP-self-signed-1437432314
 certificate self-signed 01
  3082025A 308201C3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343337 34333233 3134301E 170D3038 30343039 32313337
  31355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34333734
  33323331 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C201 43F4EDB2 ACA68DEC B5064F25 E298E19F AC8E2F5B 0EC8DC21 569E9A2C
  F2513AEC 0D28DC20 E244E12D BF31D929 17001D9C D1A805C6 2916F372 AD47918C
  694AB1AD 3405B85C 5B6285BA 09894AC5 CDB0575A DC216C8E A5D1EA11 C87104DF
  957F24B0 645D71E7 C0036279 F6048D4D AB1A967D 75D1729E 4FA67BE0 98294CDD
  965B0203 010001A3 8181307F 300F0603 551D1301 01FF0405 30030101 FF302C06
  03551D11 04253023 82214544 554F4E4C 494E452D 55433532 302E6564 75636174
  656F6E6C 696E652E 636F6D30 1F060355 1D230418 30168014 9FCD6BC9 C0BE9ED0
  3B206075 05FF7BDF 1FF5CDF1 301D0103 551D0E04 1604149F CD6BC9C0 BE9ED03B
  20607505 FF7BDF1F F5CDF130 0D06092A 864886F7 0D010104 05000381 8100506F
  51691CDE 65F1F5F3 18B80066 EEAEFBBC 433A2525 62CB9B75 491CF0B6 14E726F8
  722A832A CEB4162C DBA6462B 051FCB0D E7500EEE C71FC166 484F014B 5804ED8E
  7709FE68 76FC994E AA022B53 C610BD4C A2A538DC A011045A 18090FBC 168F5AED
  F02080E5 2B654411 4313B2AD AC584BC6 91323028 1D78304F 7240BA11 FA74
  quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.95.48.1 10.95.48.10
ip dhcp excluded-address 10.95.49.1 10.95.49.10
ip dhcp excluded-address 10.95.50.1 10.95.50.10
ip dhcp excluded-address 10.95.51.1 10.95.51.10
ip dhcp pool phone
   network 10.95.49.0 255.255.255.0
   default-router 10.95.49.1
   option 150 ip 10.95.49.1
   lease 20
ip dhcp pool data
   import all
   network 10.95.48.0 255.255.255.0
   default-router 10.95.48.1
   domain-name NET-online.com
   lease 20
ip dhcp pool WLAN
   import all
   network 10.95.50.0 255.255.255.0
   default-router 10.95.50.1
   lease 20
ip dhcp pool GUESTS
   import all
   network 10.95.51.0 255.255.255.0
   default-router 10.95.51.1
   lease 20
ip domain name NETonline.com
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
isdn switch-type primary-ni
trunk group  POTS-TG
 max-calls voice 4
 hunt-scheme round-robin
voice call send-alert
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 h323
 sip
  no update-callerid
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice hunt-group 1 parallel
 final 5441
 list 5450,5452,7901,7904,7906,7902,7911,5447,5449,7910,7900,7908,7905,7907,7909,5445,5444,5446
 timeout 9
 pilot 8101
voice logout-profile 1
 pin 1234
 number 7904 type normal
 number 5441 type overlay
voice logout-profile 2
 pin 1234
 number 7905 type normal
voice logout-profile 3
 pin 1234
 number 7906 type normal
voice logout-profile 4
 pin 1234
 number 7907 type normal
voice logout-profile 5
 pin 1234
 number 7908 type normal
voice logout-profile 6
 pin 1234
 number 7909 type normal
voice logout-profile 7
 pin 1234
 number 7910 type normal
voice user-profile 1
 pin 1234
 user EC1 password 1234
 number 5448 type normal
voice user-profile 2
 pin 1234
 user EC2 password 1234
 number 5888,5449 type normal
voice user-profile 3
 pin 1234
 user EC3 password 1234
 number 5450 type normal
voice user-profile 4
 pin 1234
 user EC4 password 1234
 number 5451 type normal
voice user-profile 5
 pin 1234
 user EC5 password 1234
 number 5452 type normal
voice user-profile 6
 pin 1234
 user EC6 password 1234
 number 5453 type normal
voice user-profile 7
 pin 1234
 user EC7 password 1234
 number 5454 type normal
voice user-profile 8
 pin 1234
 user EC8 password 1234
 number 5455 type normal
voice user-profile 9
 pin 1234
 user EC9 password 1234
 number 5456 type normal
voice user-profile 10
 pin 1234
 user EC10 password 1234
 number 5457 type normal
voice user-profile 11
 pin 1234
 user EC11 password 1234
 number 5458 type normal
voice user-profile 12
 pin 1234
 user 1 password 1234
 number 7912 type normal
voice user-profile 13
 pin 1234
 user 2 password 1234
 number 7913 type normal
voice user-profile 14
 pin 1234
 user 3 password 1234
 number 7914 type normal
voice user-profile 15
 pin 1234
 user 4 password 1234
 number 7915 type normal
voice user-profile 16
 pin 1234
 user 5 password 1234
 number 7916 type normal
voice user-profile 17
 pin 1234
 user 6 password 1234
 number 7917 type normal
voice user-profile 18
 pin 1234
 user 7 password 1234
 number 7918 type normal
voice translation-rule 1
 rule 1 /^\(.\)\(....\)/ /\2/
voice translation-rule 15
 rule 1 /^/ /1/
voice translation-rule 20
 rule 1 /57\(..\)/ /88894857\1/
voice translation-profile OUTGOING
 translate calling 20
voice translation-profile PREPEND1
 translate calling 15
voice translation-profile Xfer2VM
 translate redirect-called 1
voice-card 0
 dspfarm
dial-control-mib retain-timer 2880
dial-control-mib max-size 500
archive
 log config
  logging enable
  logging size 600
  hidekeys
controller T1 0/2/0
 framing esf
 linecode b8zs
 cablelength short 133
 pri-group timeslots 1-6,24
gw-accounting file
 cdr-format compact
interface Loopback0
 description $FW_INSIDE$
 ip address 10.1.10.2 255.255.255.252
 ip access-group 101 in
 ip nat inside
 ip virtual-reassembly
interface FastEthernet0/0
 description $FW_OUTSIDE$
 no ip address
 duplex auto
 speed auto
interface Integrated-Service-Engine0/0
 ip unnumbered Vlan49
 ip nat inside
 service-module ip address 10.95.49.2 255.255.255.0
 service-module ip default-gateway 10.95.49.1
interface FastEthernet0/1/0
 description Firewall
 switchport access vlan 48
 macro description cisco-phone
interface FastEthernet0/1/1
 description WLC
interface FastEthernet0/1/2
 switchport voice vlan 49
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
 switchport trunk native vlan 48
 switchport mode trunk
 macro description cisco-switch
interface Serial0/2/0:23
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn map address 011* plan isdn type unknown
 no cdp enable
interface Vlan1
 no ip address
interface Vlan48
 description *** DATA ***
 ip address 10.15.40.3 255.255.255.0
interface Vlan49
 description *** VOICE ***
 ip address 10.95.49.1 255.255.255.0
interface Vlan50
 description *** WLAN DATA ***
 ip address 10.95.50.1 255.255.255.0
 shutdown
interface Vlan51
 description *** Guest Vlan ***
 ip address 10.95.51.1 255.255.255.0
 ip access-group GUEST-VLAN in
 shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.15.40.1
ip route 10.95.49.2 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source list 1 interface FastEthernet0/0 overload
ip access-list extended GUEST-VLAN
 permit udp any any eq bootps
 permit udp any any eq bootpc
 deny   ip 10.95.51.0 0.0.0.255 10.0.0.0 0.255.255.255 log
 permit ip 10.95.51.0 0.0.0.255 any
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp any 10.1.10.0 0.0.0.3 range 16384 32767
access-list 103 permit udp 10.1.10.0 0.0.0.3 range 16384 32767 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any
snmp-server community public RO
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/music-on-hold-reduced.au
tftp-server flash:/phones/7940_7960/P00308001000.bin alias P00308001000.bin
tftp-server flash:/phones/7940_7960/P00308001000.loads alias P00308001000.loads
tftp-server flash:/phones/7940_7960/P00308001000.sb2 alias P00308001000.sb2
tftp-server flash:/phones/7940_7960/P00308001000.sbn alias P00308001000.sbn
tftp-server flash:/phones/7914/S00105000300.sbn alias S00105000300.sbn
tftp-server flash:/phones/7915/B015-1-0-3.SBN alias B015-1-0-3.SBN
tftp-server flash:/phones/7916/B016-1-0-3.SBN alias B016-1-0-3.SBN
tftp-server flash:/phones/7936/cmterm_7936.3-3-16-0.bin alias cmterm_7936.3-3-16-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-2-0.bin alias apps37sccp.1-3-2-0.bin
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-1-9.bin alias spa525g-7-1-9.bin
tftp-server flash:/phones/5x5/spa5x5-7-1-3c.bin alias spa5x5-7-1-3c.bin
tftp-server flash:/phones/7921/APPS-1.2.1.SBN alias APPS-1.2.1.SBN
tftp-server flash:/phones/7921/CP7921G-1.2.1.LOADS alias CP7921G-1.2.1.LOADS
tftp-server flash:/phones/7921/GUI-1.2.1.SBN alias GUI-1.2.1.SBN
tftp-server flash:/phones/7921/SYS-1.2.1.SBN alias SYS-1.2.1.SBN
tftp-server flash:/phones/7921/TNUX-1.2.1.SBN alias TNUX-1.2.1.SBN
tftp-server flash:/phones/7921/TNUXR-1.2.1.SBN alias TNUXR-1.2.1.SBN
tftp-server flash:/phones/7921/WLAN-1.2.1.SBN alias WLAN-1.2.1.SBN
tftp-server flash:/phones/7925/APPSH-1.3.1.SBN alias APPSH-1.3.1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.1.LOADS alias CP7925G-1.3.1.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.1.SBN alias GUIH-1.3.1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.1.SBN alias SYSH-1.3.1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.1.SBN alias TNUXH-1.3.1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.1.SBN alias WLANH-1.3.1.SBN
tftp-server flash:/phones/7906_7911/SCCP11.8-4-2S.loads alias SCCP11.8-4-2S.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/cnu11.8-4-1-23.sbn alias cnu11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/apps11.8-4-1-23.sbn alias apps11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-4-1-23.sbn alias dsp11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-4-1-23.sbn alias jar11sccp.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-4-1-23.sbn alias cvm11sccp.8-4-1-23.sbn
tftp-server flash:/phones/7931/SCCP31.8-4-2S.loads alias SCCP31.8-4-2S.loads
tftp-server flash:/phones/7931/cnu31.8-4-1-23.sbn alias cnu31.8-4-1-23.sbn
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7931/apps31.8-4-1-23.sbn alias apps31.8-4-1-23.sbn
tftp-server flash:/phones/7931/dsp31.8-4-1-23.sbn alias dsp31.8-4-1-23.sbn
tftp-server flash:/phones/7931/jar31sccp.8-4-1-23.sbn alias jar31sccp.8-4-1-23.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-4-1-23.sbn alias cvm31sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7941_7961/cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-4-2S.loads alias SCCP42.8-4-2S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7942_7962/cnu42.8-4-1-23.sbn alias cnu42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-4-1-23.sbn alias dsp42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/apps42.8-4-1-23.sbn alias apps42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-4-1-23.sbn alias jar42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-4-1-23.sbn alias cvm42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-4-2S.loads alias SCCP45.8-4-2S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7945_7965/cnu45.8-4-1-23.sbn alias cnu45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-4-1-23.sbn alias dsp45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/apps45.8-4-1-23.sbn alias apps45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-4-1-23.sbn alias jar45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-4-1-23.sbn alias cvm45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-4-2S.loads alias SCCP70.8-4-2S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7970_7971/cnu70.8-4-1-23.sbn alias cnu70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/apps70.8-4-1-23.sbn alias apps70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-4-1-23.sbn alias dsp70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-4-1-23.sbn alias jar70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-4-1-23.sbn alias cvm70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/SCCP75.8-4-2S.loads alias SCCP75.8-4-2S.loads
tftp-server flash:/phones/7975/cnu75.8-4-1-23.sbn alias cnu75.8-4-1-23.sbn
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/7975/apps75.8-4-1-23.sbn alias apps75.8-4-1-23.sbn
tftp-server flash:/phones/7975/dsp75.8-4-1-23.sbn alias dsp75.8-4-1-23.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-4-1-23.sbn alias cvm75sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/jar75sccp.8-4-1-23.sbn alias jar75sccp.8-4-1-23.sbn
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
voice-port 0/0/0
 timeouts interdigit 2
 timeouts ringing infinity
 description *** FAX ***
 bearer-cap Speech
 station-id name FAX
 station-id number 1070
 caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/2/0:23
voice-port 0/1/0
 trunk-group POTS-TG
 connection plar opx immediate 5440
 caller-id enable
voice-port 0/1/1
 trunk-group POTS-TG
 caller-id enable
voice-port 0/1/2
 caller-id enable
voice-port 0/1/3
 trunk-group POTS-TG
 caller-id enable
voice-port 0/3/0
 trunk-group POTS-TG
 connection plar 5441
 caller-id enable
voice-port 0/3/1
 trunk-group POTS-TG
 caller-id enable
voice-port 0/3/2
 trunk-group POTS-TG
 caller-id enable
voice-port 0/3/3
 trunk-group POTS-TG
 caller-id enable
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control -15
 description Music On Hold Port
sccp local Vlan49
sccp ccm 10.95.49.1 identifier 1
sccp
sccp ccm group 1
 associate ccm 1 priority 1
dial-peer cor custom
 name INTERNAL
 name LOCAL
 name DOMESTIC
 name INTERNATIONAL
 name 900
 name 976
 name SERVICE
 name EMERGENCY
dial-peer cor list COR-INTERNAL
 member INTERNAL
 member EMERGENCY
dial-peer cor list COR-LOCAL
 member SERVICE
 member EMERGENCY
dial-peer cor list COR-DOMESTIC
 member INTERNAL
 member DOMESTIC
 member SERVICE
 member EMERGENCY
dial-peer cor list COR-INTERNATIONAL
 member INTERNAL
 member DOMESTIC
 member INTERNATIONAL
 member SERVICE
 member EMERGENCY
dial-peer voice 10 pots
 translation-profile incoming PREPEND1
 translation-profile outgoing OUTGOING
 destination-pattern 1..........
 incoming called-number .T
 direct-inward-dial
 port 0/2/0:23
 forward-digits all
dial-peer voice 8000 voip
 translation-profile outgoing Xfer2VM
 destination-pattern 800.
 session protocol sipv2
 session target ipv4:10.95.49.2
 incoming called-number D80....
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 15 pots
 destination-pattern 011T
 direct-inward-dial
 port 0/2/0:23
 forward-digits all
dial-peer voice 11 pots
 destination-pattern [3,4,6,9]11
 port 0/2/0:23
 forward-digits all
dial-peer voice 12 pots
 trunkgroup POTS-TG
 preference 2
 forward-digits all
dial-peer voice 13 pots
 trunkgroup POTS-TG
 preference 2
 forward-digits all
dial-peer voice 1 pots
 description ***FAX****
 destination-pattern 1070
 port 0/0/0
 forward-digits all
dial-peer voice 7000 voip
 destination-pattern 70..
 session target ipv4:10.1.1.250:5060
 session transport tcp
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
no dial-peer outbound status-check pots
telephony-service
 video
 authentication credential admin R0ckp0rt
 load 7914 S00105000300
 load 7915-12 B015-1-0-3
 load 7915-24 B015-1-0-3
 load 7916-12 B016-1-0-3
 load 7916-24 B016-1-0-3
 load 7902 CP7902080002SCCP060817A
 load 7906 SCCP11.8-4-2S
 load 7911 SCCP11.8-4-2S
 load 7921 CP7921G-1.2.1
 load 7925 CP7925G-1.3.1
 load 7931 SCCP31.8-4-2S
 load 7936 cmterm_7936.3-3-16-0
 load 7937 apps37sccp.1-3-2-0
 load 7960-7940 P00308001000
 load 7941 SCCP41.8-4-2S
 load 7941GE SCCP41.8-4-2S
 load 7942 SCCP42.8-4-2S
 load 7945 SCCP45.8-4-2S
 load 7961 SCCP41.8-4-2S
 load 7961GE SCCP41.8-4-2S
 load 7962 SCCP42.8-4-2S
 load 7965 SCCP45.8-4-2S
 load 7970 SCCP70.8-4-2S
 load 7971 SCCP70.8-4-2S
 load 7975 SCCP75.8-4-2S
 load 521G-524G cp524g-8-1-17
 load 525G spa525g-7-1-9
 load 501G spa5x5-7-1-3c
 load 502G spa5x5-7-1-3c
 load 504G spa5x5-7-1-3c
 load 508G spa5x5-7-1-3c
 load 509G spa5x5-7-1-3c
 max-ephones 40
 max-dn 160
 ip source-address 10.95.49.1 port 2000
 auto assign 10 to 43
 auto assign 5 to 8 type anl
 calling-number initiator
 service phone videoCapability 1
 service dnis overlay
 service dnis dir-lookup
 timeouts interdigit 5
 system message NET ONLINE
 url services http://10.95.49.2/voiceview/common/login.do
 time-zone 12
 voicemail 8000
 max-conferences 8 gain -6
 call-park system redirect
 call-forward pattern .T
 call-forward system redirecting-expanded
 moh music-on-hold-reduced.au
 multicast moh 239.10.16.16 port 2000
 web admin system name admin secret 5 $1$a0Nj$OybrlAboSkbEEBQD24uAC/
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern 9.T
 transfer-pattern .T
 after-hours block pattern 1 1900....... 7-24
 directory last-name-first
 create cnf-files version-stamp 7960 Oct 08 2014 06:27:45
ephone-template  15
 softkeys remote-in-use  Newcall
 softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
 softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
 softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
 button-layout 7931 2
ephone-template  16
ephone-template  17
 softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  2  octo-line
 number 5759
 name Baltimore Conf Rm
 call-forward all 8000
 call-forward busy 8000
 call-forward noan 8000 timeout 10
 number 5761
 call-forward noan 8000 timeout 20
ephone-dn  15  dual-line
 number 5768
ephone-dn  39  dual-line
 number 5772
 label 5772
 name 5772
ephone-dn  71
 number 81
 park-slot
ephone-dn  72
 number 82
 park-slot
ephone-dn  73
 number 83
 park-slot
ephone-dn  97
 number *....
ephone-dn  98
 number D9....
 mwi on
ephone-dn  99
 number D8....
 mwi off
ephone-dn  100
 number 8100
 name PAGING ALL
 paging ip 239.0.1.20 port 2000
ephone  1
 device-security-mode none
 mac-address 001E.7AC5.04D4
 paging-dn 100
 type 7941
 button  1:10
ephone  2
 mac-address 001E.BE8F.F31C
 paging-dn 100
 type 7941
 button  1:3
ephone  5
 mac-address 001E.BE8F.EA79
 type 7941
 button  1:11
ephone  6
 mac-address 001E.BE8F.7BF3
 type 7941
 button  1:6
ephone  8
 mac-address 001E.BE8F.7B8F
 paging-dn 100
 type 7941
 button  1:8
ephone  10
 mac-address 001E.7AC5.004D
 paging-dn 100
 type 7941
ephone  11
 mac-address 001E.BE8F.F315
 type 7941
 button  1:14
ephone  12
 mac-address 001E.BE8F.EC8D
 paging-dn 100
 type 7941
 button  1:12
ephone  13
 mac-address 001E.BE8F.E9CF
 button  1:13
ephone  14
 mac-address 001E.BE8F.F379
 type 7941
 button  1:2
ephone  15
 mac-address 001E.BE8F.F46B
 paging-dn 100
 type 7941
 button  1:15
ephone  16
 mac-address 001E.BE8F.F8A6
 button  1:16
ephone  17
 mac-address 001E.BE8F.F92E
 button  1:17
ephone  20
 mac-address 001E.BE8F.F36D
 paging-dn 100
 type 7941
 button  1:20
ephone  21
 mac-address 001E.BE8F.F3D2
 paging-dn 100
 type 7941
 button  1:39
ephone  22
 mac-address 0024.81F6.C2FC
 type CIPC
 button  1:13
ephone-hunt 2 peer
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Tue Feb 17 22:28:54 EST 2015^C
line con 0
 login local
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 exec-timeout 60 0
 login local
line vty 5 15
 exec-timeout 60 0
 login local
line vty 16 100
 login local
ntp master
ntp server 192.5.41.40
end
Chris,
Question on the DISCONNECT cause
"Feb 18 17:17:24.615: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8986
This message is coming from the carrier right? It looks as if I am sending them 1+10 digits:
     <--snip-->
And then they disconnect almost immediately, but it comes from the carrier. Maybe they don't like the redirect? In normal outgoing calls, that work, we send the carrier 1+10.
