CME cfwd no answer to CUE
p.holley
I have two sites (A and B) running CME/CUE. I have configured transcoding on both CME's. However when I call from either sites to the other, the phone does not ring no answer to voice mail. The caller gets silence after the noans timeout.
I have attached my transcoding configuration. I am running CME4.2 with IOS 12.4XW2
paolo bevilacqua
Does it work without transcoding in first place ?
Thanks for your response. I never tried it without transcoding. how will it work without transcoding, since the VoIP calls are using G.729 and CUE G.711.
Have you got it to work without using transcoding?
Tha
Well unless you have configured g.729 under ephone, the calls will be g711u. My suggestions was to try with this default configuration.
