CME Conferencing
JustForVoice_2
Level 4
Level 4
Hi all,
Is there any way to configure software conference bridge in CME rather than hardware, because I do not have enough PVDMs?
nitsinha
Level 4
Level 4
You can only have a software based 3 party ad-hoc conferencing(multi-party not supported on software based conferencing, you will need PVDM's for that). Check the following doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1010534
Hope that helps
Nitesh
PS: Pl rate helpful posts
nitsinha
Level 4
Level 4
Hope that helps
Nitesh
Thnak you for your reply
