02-28-2014 01:51 PM - edited 03-16-2019 09:57 PM
Hi All. Interesting but frustrating situation. Have a CUE-AIM running on a c2811. I am unable to record name/outgoing message when performing initial mailbox settup, as well as calls forwarded hear a prompt, but no message is recorded. I have verified IP connectivity to and from the CUE, and even see debug RTP packets passing from the CME to CUE module. I'm at a loss for what to do next due to lack of experience debugging the CUE.
CME version is 7.1
C2811 version is 12.4(24)T8
CUE is 7.0.6
SIP calls to/from provider are all working fine, so it seems my issue is on the CUE config. I hope it's not something obvious.
Anyone ever seen this proplem? Ideas for how to debug?
Thanks, much.
--matt
02-28-2014 02:44 PM
Matt,
Can you check that you have "no vad" on your dial peer from the cme to the cue
Alex.
Please rate useful posts.
02-28-2014 04:36 PM
Hi Alex,
I wish it was that simple. "no vad" is on all voip dial peers. It has been since I first started, but that didnt stop me from checking it ten times!
--matt
dial-peer voice 700 voip
destination-pattern 7..
session protocol sipv2
session target ipv4:10.10.13.13
dtmf-relay sip-notify
codec g711ulaw
no vad
