CME Debugging
Ahmed habib
Level 3
Level 3
Hello, I am having CME 11.5 on router 2911
when I write any debug command to examine a call ,it says that the debug is on but there is nothing appear although the call is operating and changes occur
What shall I do ?
Issue "logging monitor" at global configuration mode.
Georgios
Please rate if you find this helpful.
5 Replies 5
Georgios Fotiadis
If you have used telnet/ssh to login to the device, you need issue "terminal monitor" in privileged more; this command is not needed when you connect through console.
Alternatively you can use "logging buffered" to write debug output to local buffer and later view it with "show logging".
Georgios
I did term mon but nothing appears
I want to see that real time, Is there a solution ?
If "term mon" is open, and you simply issue "conf t" and then "exit", do you see anything on the screen? How have you connected to the device?
Georgios
CME#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CME(config)#exit
I access it using ssh
Georgios
