CME Feature-button on 7975 for NightService
Michael Durham
Level 4
Level 4
I have two 7975 phones and everything is working fine.
I am trying to put the feature NightService on button 8 of the phone so that we can just push the button to enable or disable the NightServie.  From what i have read, doing this will also light up the button when NightService is on.  BUT, I just cannot seem to get it to work on the button. Button 8 has no label and does nothing.
Night Service IS working fine.  The code is *99 to enable and disable it.  When the service is enabled, the message on the bottom of the display states Night Service is Enabled.  So far, so good.
If I use blf-speeddial 8 *99 label NightService, I can enable and disable the service with just one touch of the button.  But, the button does not light up this way.
Using the feature-button command is supposed to do both enable and disable AND light up the button ling.
Below is my config and any help would be very kind of you.
!telephony-service
night-service code *99
night-service day Sun 08:00 07:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 08:00 07:59
night-service day Sat 08:00 07:59
fac standard
ephone-template 3
feature-button 8 NiteSrv label "On/Off Night Service"
conference drop-mode creator
conference add-mode creator
conference admin
transfer max-length 11
softkeys remote-in-use CBarge Newcall
softkeys hold Resume Newcall Select Join
softkeys idle Redial Newcall Cfwdall Dnd Mobility Pickup Join ConfList RmLstC
softkeys seized Redial CWOff Cfwdall Callback Endcall Meetme
softkeys alerting Endcall Callback
softkeys connected Hold Park Trnsfer TrnsfVM Mobility Select Join Confrn ConfList RmLstC Endcall
softkeys ringing Answer Dnd
button-layout 1-2 line
button-layout 9 speed-dial
button-layout 3-7 blf-speed-dial
button-layout 8 feature
ephone 13
device-security-mode none
description Receptionist One
mac-address 8478.ACE7.
ephone-template 3
busy-trigger-per-button 4
username "rone"
blf-speed-dial 1 111 label "Dr. Jeff " device
blf-speed-dial 2 112 label "Debbie " device
blf-speed-dial 3 115 label "Consultation" device
blf-speed-dial 4 116 label "Sterilization" device
blf-speed-dial 5 117 label "Lounge" device
type 7975
mwi-line 2
button 1:13 2:1
ephone 14
description Receptionist Two
ephone-template 3
username "rtwo"
blf-speed-dial 1 111 label "Dr. Jeff" device
blf-speed-dial 2 112 label "Debbie" device
type 7975
mwi-line 2
button 1:14 2:1
I have tried putting the command feature-button 8 NiteSrv label "On/Off Night Service" directly in the ephone 13 config but that does not help.  I have rebuilt the cnf files too.
0 Replies 0
