CME forced auth codes in 8.5/8.6
thisisshanky
Level 11
Level 11
I m referring to this document (which doesnt seem to help me much)..so thought of posting at this forum....
Has any body successfully implemented FAC in CME..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
i have setup two LPCor groups one for end users and one for PSTN trunks..to test this functionality i put one ephone under the end users group and another ephone in the PSTN trunk group..and when you call from ephone 1 to 2...it asks for the username and password as programmed but then it hangs up the call...
i can post configs if needed...its pretty similar to whats in the document..
TIA..
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
50 Replies 50
Praveen Arak
Dear Team ,
                 Can any body please provide guidance  for single one time pin authentication for LP COR FAC in CME 9.x . Do please suggest and advise doe the best .
Praveen
mraj_ Seed
hi Shanky,
am facing issue with this config, the audio file are not on my root flash, will it work ?
Hello All,
I think this link will help you resolve all your issues.
https://supportforums.cisco.com/discussion/11147326/how-get-lpcor-working-cme-85
It also contains the 123630-FAC-SBCS.zip file that contains the audio files, that will make the LPCOR work.
Trust this helps.
Let me know, if any of you face any issues.
Venkitesh
asotojimenezz
Hello everyone
I need help.which is my mistake ??
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
gw-accounting aaa
aaa session-id common
trunk group Telmex-E1
 hunt-scheme least-idle
voice lpcor enable
voice lpcor custom
 group 10 end-user
 group 11 pstntrunk
voice lpcor policy end-user
 service fac
 accept end-user fac
 accept pstntrunk fac
voice lpcor policy pstntrunk
 service fac
 accept end-user fac
application
 package auth
  param passwd-prompt flash:enter_pin.au
  param max-retries 0
  param passwd 1973285
  param abort-digit *
  param user-prompt flash:enter_account.au
  param term-digit #
  param max-digits 32
username 1 password 0 91724
username 2 password 0 50476
username 3 password 0 87123
username 4 password 0 98237
username 5 password 0 10568
username 6 password 0 29561
username 7 password 0 56102
username 8 password 0 43875
username 9 password 0 87325
username 10 password 0 31854
username 11 password 0 69425
username 12 password 0 79161
username 13 password 0 94989
username 14 password 0 65443
controller E1 0/0/0
 framing NO-CRC4
 line-termination 75-ohm
 ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
 cas-custom 0
  country telmex
  category 2
  answer-signal group-b 1
  caller-digits 4
  dnis-digits min 4 max 13
  dnis-complete
  timer interdigit incoming 1000
  groupa-callerid-end
  trunk-group Telmex-E1
dial-peer voice 921 pots
 trunkgroup Telmex-E1
 corlist outgoing CallCelularLocal
 destination-pattern 9044..........
 incoming called-number 9044..........
 direct-inward-dial
 prefix 044
dial-peer voice 931 pots
 corlist outgoing CallCelularNacional
 destination-pattern 9045..........
 incoming called-number 9045..........
 direct-inward-dial
 prefix 045
dial-peer voice 941 pots
 corlist outgoing CallLD-Nacional
 destination-pattern 901..........
 incoming called-number 901..........
 direct-inward-dial
 prefix 01
voice register pool  2
 pin 50476
 lpcor type local
 lpcor incoming superuser
 busy-trigger-per-button 2
 id mac 547C.69D7.6706
 type 7841
 number 1 dn 2
 cor incoming Nivel3 default
 presence call-list
 dtmf-relay rtp-nte sip-notify
 username 2 password 50476
 description 7841
 codec g711ulaw
Regards.
Amit23
Level 4
Level 4
how can apply FAC as we have SIP trunk with cme 10.5?
what would change in configuration for FAC in CME?
Warm Regard's
Amit Sahrma
Please review this link for the explanation
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmelpcor.html#46541
SUMMARY STEPS
1. enable
2. configure terminal
3. voice lpcor ip-trunk subnet incoming
4. index index-number lpcor-group { ipv4-address network-mask | hostname hostname }
5. exit
6. voice service voip
7. lpcor incoming lpcor-group
8. exit
9. dial-peer voice tag voip
10. lpcor outgoing lpcor-group
11. end
Examples
The following example shows a LPCOR configuration for VoIP trunks:
index 1 h323_group1 172.19.33.0 255.255.255.0
index 2 sip_group1 172.19.22.0 255.255.255.0
index 3 sip_group2 hostname sipexample
voice service voip
lpcor incoming voip_trunk_1
dial-peer voice 233 voip
description H323 trunk outbound dial-peer
destination-pattern 233T
session target ipv4:172.19.33.233
lpcor outgoing h323_group1
dial-peer voice 2255 voip
description SIP trunk outbound dial-peer
destination-pattern 255T
session protocol sipv2
