CME GUI doesn't put phone type into config
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
#sho telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.96.200.25 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 42
max-dn 144
max-conferences 3 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] RU   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] RU    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh flash:/cme/music-on-hold.au
time-format 24
date-format dd-mm-yy
timezone 43 Taipei Standard Time
call-forward pattern .T
call-forward system redirecting-expanded
transfer-pattern .T
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 60
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message UTair Krasnoyarsk
web admin system name Admin
web admin customer name Customer
edit DN through Web:  enabled.
edit TIME through web:  disabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 May 05 2012 17:23:57
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Whenever i add a phone using GUI, phone works fine except it doesn't load locale.
After some investigating and forum digging, i found what the main problem is that there is no type option added into config, and so IOS does not creafe phone cnf file and phone doesn't load per type config neither.
when i try to set phone type manually, it complains like this, maybe that's the thing GUI missing?
(config-ephone)#type 6921
Force max-calls-per-button to 2
(config-ephone)#max-calls-per-button 2
Is that IOS bug?
paolo bevilacqua
CME GUI doesn't give good results for configuration or administration.
You need to use CLI, or you can try the CCP GUI.
