CME Hunt Group Rings Extensions then drops call instead of queuing
d4rr0nl3gn0n
An external caller calls in and gets the AA. They select the menu option wanted and then rings the 3 phones in the hunt group. After ringing all 3 phones with no answer the call drops instead of going into a call queue. Any ideas?
d4rr0nl3gn0n
Below is the "debug voice ccapi all" after the call rings the hunt group extensions and drops.
000944: //50/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
Call Entry Is Not Found
000945: //50/xxxxxxxxxxxx/CCAPI/cc_api_request_rt_packet_stats:
CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
000946: //53/DFBB21438037/CCAPI/cc_api_call_disconnected:
Cause Value=19, Interface=0x8B0AE708, Call Id=53
000947: //53/DFBB21438037/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
000948: //46/DFBB21438037/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
000949: //53/DFBB21438037/CCAPI/cc_api_get_transfer_info:
000950: //53/DFBB21438037/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
000951: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
Precedence not above Routine
000952: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=A5001A0002, Called Number=A5001A0002, Calling Number=2105551234, Calling DN=-1 Calling Id=46,
Redirect Number=A5001A0000, Redirect Reason=2
000953: //53/DFBB21438037/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=53
000954: //53/DFBB21438037/CCAPI/ccCallDisconnect:
Cause Value=19, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
000955: //53/DFBB21438037/CCAPI/ccCallDisconnect:
Start Calling Accounting;
Call Entry(Incoming=FALSE)
000956: //53/DFBB21438037/CCAPI/ccCallDisconnect:
Cause Value=19, Call Entry(Disconnect Cause=19)
000957: //53/DFBB21438037/CCAPI/ccCallDisconnect:
000958: //53/DFBB21438037/CCAPI/ccCallDisconnect:
Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
000959: //53/DFBB21438037/CCAPI/cc_api_get_transfer_info:
000960: //53/DFBB21438037/CCAPI/cc_api_get_transfer_info:
000961: //46/DFBB21438037/CCAPI/ccGetCurrentCodec:
000962: //46/DFBB21438037/CCAPI/ccDisassociateStream:
Record Context=0x0, Stream Call Id=50, Call Id=46
000963: //46/DFBB21438037/CCAPI/ccDisassociateStream:
Call Entry(Stream Status=1, Digit Enable=FALSE)
000964: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
000965: //53/DFBB21438037/CCAPI/cc_api_insert_call_history:
000966: //53/DFBB21438037/CCAPI/ccGetCallActiveByCallID:
000967: //53/DFBB21438037/CCAPI/ccGetCallActiveByCallID:exit@12594
000968: //53/DFBB21438037/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x8B0AE708, Tag=0x0, Call Id=53,
Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
000969: //53/DFBB21438037/CCAPI/cc_disconnect_notify:
000970: //53/DFBB21438037/CCAPI/callStackPop:exit@4886
000971: //53/DFBB21438037/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
000972: //53/DFBB21438037/CCAPI/cc_delete_guid_pod_entry:
Incoming=FALSE
000973: //53/DFBB21438037/CCAPI/cc_delete_guid_pod_entry:exit@1165
000974: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000975: :cc_free_feature_vsa freeing 8737E2B0
000976: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000977: vsacount in free is 9
000978: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000979: vsacount in free is 8
000980: //53/DFBB21438037/CCAPI/cc_delete_call_entry:
Total Call Count=2, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
000981: //53/DFBB21438037/CCAPI/cc_delete_call_entry:
Deleting profileTable[0x8BD277B0]
000982: //53/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
000983: //-1/xxxxxxxxxxxx/CCAPI/ccGetCallGCID:
000984: //53/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
000985: //-1/xxxxxxxxxxxx/CCAPI/ccSetCallGCID:
000986: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
000987: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
000988: //47/DFBB21438037/CCAPI/ccCallFacility:
Call Id=47
000989: //53/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
000990: //50/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
000991: //50/xxxxxxxxxxxx/CCAPI/cc_api_request_rt_packet_stats:
000992: //46/DFBB21438037/CCAPI/ccCallDisconnect:
Cause Value=19, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000993: //46/DFBB21438037/CCAPI/ccCallDisconnect:
Call Entry(Incoming=TRUE)
000994: //46/DFBB21438037/CCAPI/ccCallDisconnect:
Cause Value=19, Call Entry(Disconnect Cause=0)
000995: //46/DFBB21438037/CCAPI/ccCallDisconnect:
000996: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
000997: //47/DFBB21438037/CCAPI/ccCallDisconnect:
000998: //47/DFBB21438037/CCAPI/ccCallDisconnect:
000999: //47/DFBB21438037/CCAPI/ccCallDisconnect:
001000: //47/DFBB21438037/CCAPI/ccCallDisconnect:
001001: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
001002: //-1/xxxxxxxxxxxx/CCAPI/ccGenerateToneInfo:
001003: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
001004: //-1/xxxxxxxxxxxx/CCAPI/ccGenerateToneInfo:
001005: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
ExpectFactor=0xA
001006: //47/DFBB21438037/CCAPI/cc_api_insert_call_history:
001007: //47/DFBB21438037/CCAPI/ccGetCallActiveByCallID:
001008: //47/DFBB21438037/CCAPI/cc_decr_if_call_volume:
001009: //47/DFBB21438037/CCAPI/cc_decr_if_call_volume:
Remote IP Address
001010: //47/DFBB21438037/CCAPI/cc_decr_if_call_volume:
Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
001011: //47/DFBB21438037/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x87B87714, Tag=0x0, Call Id=47,
001012: //47/DFBB21438037/CCAPI/cc_disconnect_notify:
001013: //47/DFBB21438037/CCAPI/callStackPop:exit@4886
001014: //47/DFBB21438037/CCAPI/cc_api_call_disconnect_done:
001015: //47/DFBB21438037/CCAPI/cc_delete_guid_pod_entry:
Incoming=FALSE
001016: //47/DFBB21438037/CCAPI/cc_delete_guid_pod_entry:exit@1165
001017: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001018: :cc_free_feature_vsa freeing 8737DE50
001019: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001020: vsacount in free is 7
001021: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001022: vsacount in free is 6
001023: //47/DFBB21438037/CCAPI/cc_delete_call_entry:
001024: //47/DFBB21438037/CCAPI/cc_delete_call_entry:
Deleting profileTable[0x8BD28458]
001025: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
001026: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
001027: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
ExpectFactor=0xA
001028: //46/DFBB21438037/CCAPI/cc_api_insert_call_history:
001029: //46/DFBB21438037/CCAPI/ccGetCallActiveByCallID:
001030: //46/DFBB21438037/CCAPI/cc_decr_if_call_volume:
001031: //46/DFBB21438037/CCAPI/cc_decr_if_call_volume:
Remote IP Address
001032: //46/DFBB21438037/CCAPI/cc_decr_if_call_volume:
001033: //46/DFBB21438037/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x87B87714, Tag=0x0, Call Id=46,
001034: //46/DFBB21438037/CCAPI/cc_disconnect_notify:
001035: //46/DFBB21438037/CCAPI/callStackPop:exit@4886
001036: //46/DFBB21438037/CCAPI/cc_api_call_disconnect_done:
001037: //46/DFBB21438037/CCAPI/cc_delete_guid_pod_entry:
Incoming=TRUE
001038: //46/DFBB21438037/CCAPI/cc_delete_guid_pod_entry:exit@1165
001039: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001040: :cc_free_feature_vsa freeing 8737E010
001041: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001042: vsacount in free is 5
001043: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001044: vsacount in free is 4
001045: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001046: vsacount in free is 3
001047: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001048: vsacount in free is 2
001049: //46/DFBB21438037/CCAPI/cc_delete_call_entry:
Total Call Count=2, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
001050: //46/DFBB21438037/CCAPI/cc_delete_call_entry:
Total Call Count=1
001051: //46/DFBB21438037/CCAPI/cc_delete_call_entry:
Deleting profileTable[0x8BD28228]
001052: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
001053: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
