CME IINET SIP Trunk
David Belyea
G'day
Just wondering if anyone might have an idea why what would be wrong with my config i have been trying to get the CME to work with a IINet SIP trunk
all i got from them is
Number range:   08 XXXX X880 - 08 XXXX X899
Domain/realm:   comapnyname.iibusiness.net.au
SIP proxy: sip. wa.iibusiness.net.au
SIP username:   0XXXXXXX1
SIP password:   yXXXX8
Capacity:       4 concurrent calls
This is the Current config for that  the config works for outbound calls perfectly but inbound just fails to connect anyone got any ideas?
ill attach a debug. if anyone can help be greatly apreciated.
voice service voip
allow-connections sip to sip
redirect ip2ip
fax protocol pass-through g711alaw
modem passthrough nse codec g711alaw
sip
  localhost dns:Companyname.iibusiness.net.au
  outbound-proxy ipv4:203.59.49.8
  no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice translation-rule 1
rule 1 /8[89]./ /0XXXXXX\0/
voice translation-rule 2
rule 1 /^08XXXXXX88$/ /889/
voice translation-rule 100
rule 1 /.*/ /08XXXXXX888/
voice translation-rule 101
rule 1 /^08XXXXX888$/ /889/
voice translation-profile IINET-INCOMING
translate called 2
voice translation-profile IINET-OUTGOING
translate calling 1
voice translation-profile Incoming_Number
translate called 101
voice translation-profile Outgoing_Number
translate calling 100
dial-peer voice 100 voip
description *** SIP Trunk Incoming from iiNet ***
translation-profile incoming Incoming_Number
destination-pattern 08XXXXX888
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
dtmf-relay sip-notify rtp-nte
dial-peer voice 4 voip
description Test voip
destination-pattern 04........
translate-outgoing calling 1
codec g711alaw
clid network-number 08XXXXXX88
dial-peer voice 1 voip
description Test Voip
translation-profile outgoing Outgoing_Number
destination-pattern .T
voice-class codec 1
no vad
sip-ua
authentication username 0XXXXXXXXX1 password 7 0XXXXXXXXXXXXXXXXX51
no remote-party-id
retry invite 2
retry register 3
timers connect 100
registrar dns:companyname.iibusiness.net.au expires 3600
sip-server dns:companyname.iibusiness.net.au
telephony-service
no auto-reg-ephone
max-ephones 42
max-dn 100
ip source-address 10.0.10.10 port 2000
cnf-file location flash:
load 7970 SCCP70.9-1-1SR1S
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Aug 05 2011 09:46:30
ephone-dn  88
number 0XXXXXX88
ephone-dn  89
number 889
ephone  1
device-security-mode none
mac-address 0012.XXXX.XXX7
button  1:89 2:88
David Belyea
Ok Problem Solved
ip address trusted list
  ipv4 203.59.49.8
version 15.X has default securty built in
thanks
Dave
