Installing subscriber callmanager 7.0 failes
saeed-zamani
Hello
I faced strange problem today. I have CUCM 7.0 as a publisher. today I try to install subscriber with excact same version.
When  installation reaches integration step with publisher, I enter publisher  hostname, IP address and security password but validation failes.
I do following steps to fix a problem with no luck:
1- I reset security password in publisher using "pwrecovery" and "pwreset".
2- reboot publisher CUCM.
3- change hostname in publisher.
4- connect publisher and subscriber with cross cable.
I  add subscriber IP address In "server" tab in CUCM publisher. I think  everythink is ok. I install publisher ans subscriber many times but I  don't know why this time this problem happens.
Only  difference between this time and other intallations is that when I  installed publisher, I enable DNS. I read some post about DNS problem. I  also disable DNS on publisher but the problem doesnt fixed. I had both  servers host name in DNS.
Any help will be appriciated.
jfernandorosa
I recomend with you reinstall Publisher e Subscriber e not use de DNS,even removing the entry, you will find different problems and will be very difficult for him to accept the cluster. Do not use cross cable, use a layer 3 to simulate the network and default gateway.
Regards.
Joao
for SMTP, NTP and DNS I prefer to set them later after installation but while installation choose NO and conitnue with your installation don't make it hard
