03-18-2011 05:12 AM - edited 03-16-2019 04:01 AM
Hello!
I am trying to configure my CME with SIP trunk. My outgoing calls work fine, but i have problems with an incomming calls.
When i call from my mobile, the extention behind CME ring....but there is no voice.
Thanks in advanced.
Solved! Go to Solution.
03-19-2011 07:10 AM
What's the codec we are supposed to use be talking to the ITSP? G711alaw?
I see
voice class codec 1
codec preference 1 g711alaw
*Mar 18 15:14:30.471: //-1/41CAFF398326/CCAPI/cc_api_call_setup_ind_common:
Interface=0x48FEE7B8, Call Info(
Calling Number=0895xxxxxx,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=101562xxxxxxxxxxxxx(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=5000, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1176
*Mar 18 15:14:30.471: //-1/41CAFF398326/CCAPI/ccCheckClipClir:
Mar 18 15:14:30.483: //1176/41CAFF398326/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x49EA8F18, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=0895xxxxxx,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=2001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20001, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar 18 15:14:30.483: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
I see it matching the right dial-peers. Get me those debugs
plus
show voip rtp connection
show call active voice brief
/divin
03-19-2011 09:31 AM
hello!
if i bind either signaling or media with internal interface fa0/1 it's stop working.
Actually after Wireshark dump on my WAN interface i noticed that my provider don't wait me to send 200 OK SDP. SIP proxy send before sip cancel message.
How can i reduce that time?
03-19-2011 12:46 PM
My mistake...you need to bind it to the external interface!
can you make a test call and send me the debugs..
debug voip ccapi inout
debug ccsip message
From you previous messages, I thought the call stays UP...but there's no AUDIO?
/divin
PS:Rate only useful posts!
