12-07-2015 04:39 AM - edited 03-17-2019 05:08 AM
I have a customer who is a medical practise using a CME and an incoming script for their main number. The only outstanding issue for them was the fact they only had 10 lines and they were all being used in the morning by incoming calls. They needed to restrict the number of incoming calls as it was important to make outgoing also.
After implementing the MAX-CONN command I was able to limit the calls to 8 on the incoming dial-peer. The issue is that the 9th caller is getting cut off rather than a busy tone, which is what the customer is insisting they want. see out put for call below where the call is coming in and correctly unaccepted, but is there a way to get the busy tone rather than: Cause i = 0x80AF - Resource unavailable, unspecified.
Is there a way to make the box play the engaged tone?
948135: Dec 7 12:13:05.827: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x27F0
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98386
Exclusive, Channel 6
Date/Time i = 0x0F0C070C0D
Date (dd-mm-yr) = 15-12-07
Time (hr:mnt:sec) = 12:13:108
Calling Party Number i = 0x0183, '07968514050'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '60000'
Sending Complete
948136: Dec 7 12:13:05.827: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0xA7F0 callID = 0x67C6 switch = primary-net5 interface = User
948137: Dec 7 12:13:05.831: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 19
948138: Dec 7 12:13:05.831: %VOICE_IEC-3-GW: CCAPI: Internal Error (Dial-peer connections exceeded): IEC=1.1.181.1.21.0 on callID 0
948139: Dec 7 12:13:05.831: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA7F0
948140: Dec 7 12:13:05.871: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3583255 GUID=709DA70D9C1211E5A798C47D4FBBAE80
--More-- 948141: Dec 7 12:13:05.871: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 3583255 GUID=709DA70D9C1211E5A798C47D4FBBAE80
948142: Dec 7 12:13:05.875: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.114 on callID 3583255
Solved! Go to Solution.
12-07-2015 05:12 AM
Please configure following command under serial interface and see if it makes any difference;
isdn disconnect-cause busy
- Vivek
12-07-2015 05:12 AM
- Vivek
