10-29-2008 07:30 AM - last edited on 03-25-2019 07:45 PM by ciscomoderator
Hello All,
Using CME 4.3 IOS 12.4.20T
I have used num-exp as follows
num-exp 11111 91231111
num-exp 22222 91232222
I am able to call 11111 and it gets translated properly. However, I am NOT able to transfer to 11111 I get a fast-busy.
I was wondering if anyone would know how to transfer to a number that has been num-exp 'ed.
I also tried to create a translation pattern > apply it to a translation profile > apply it to the voice-port, and still no go as follows. I still get the fast-busy
voice translation-rule 6
rule 7 /\(11111$\)/ /912311111/
rule 8 /\(22222$\)/ /912322222/
voice translation-profile Internal-Transfer
translate called 6
voice-port 0/2/0:0
translation-profile outgoing Internal-Transfer
Any hints at this point would be greatly appreciated.
10-29-2008 08:28 AM
Can you transfer directly to 91231111?
Can you post your telephony-service config?
Chris
10-29-2008 08:49 AM
Chris,
Yes I am able to transfer directly to that number.
I have been able to resolve this issue. The problem was that my transfer pattern was set to 9T in telephony services. I have set it to .T and things are working smoothly.
Deepak
10-29-2008 08:50 AM
Deepak,
That's exactly where I was getting :-) Happens a lot.
Chris
