You can use preference command under your ephone hunt-group or voice
hunt-group.
For example:
dial-peer voice 10 voip
description ***** unity connection ****
destination-pattern 842555555
session target ipv4:1.1.1.1
dtmf-relay sip-kpml rtp-nte
session protocol sipv2
voice hunt-group 10 parallel
pilot 842555555
preference 5
I you use show dial-peer voice summary, you will see two dialpeers with the
one towards CUC taking precedence.
