CME Singapore Dial Plan
mattiep00
Does anyone have a sample dial plan (dial-peers) for Singapore based sites? Or is there somewhere to find dial plans based on countries? I am also looking for an Australian one...
Thanks!
singhcisco
Are you planning to use a GW or Telco to make calls to Singapore/Australia.
If you are planning to make use of GW then make a VOIP dial peer but if you will use Telco then use Serial/FXO port to make outbound calls to Singapore/Australia
Use destination pattern of 011 .T
and use Prefix command and add country code.
He isn't planning on making calls to these sites but from them. The destination-pattern provided looks like your sourcing the call from the United States.
I am sure you already look on Wikipedia, but it is usually a good starting point:
http://en.wikipedia.org/wiki/+65
I have had good look on the forums here hopefully someone with an install in Singapore can help more.
no I have not.
But where are you ORIGINATING your calls from?
I had already looked on Wikipedia - just thought someone might already have a configuration ready to go.
Anyone? Without having to re-invent the wheel...
