11-09-2011 03:56 AM - edited 03-16-2019 07:57 AM
Hello
All our PSTN & DID/DOD lines from provider are terminated on Nortel CS 1000E. I need to build a SIP Trunk between CME and Nortel PBX.
Link provided by nortel engineer is between CUCM & Nortel, dont see any link for CME. Anyone aware then please share the link
Here is link between CUCM & Nortel
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/523948nt.pdf
Anthony
11-09-2011 04:46 AM
Anthony
Use this link as a reference.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/795623.pdf
It may not be your exact version numbers etc
But the general info will be good
Alex
Please rate useful posts
11-09-2011 05:59 AM
Hi Alex
Thanks for sharing the link. The information is good in the document. I am not clear on the exact command needed to establish a SIP trunk between CME & Nortel
I see only these commands some what related to SIP
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server
11-09-2011 06:17 AM
Anthony
It depends on what the CME is running
In the example quoted in the pdf the CME is running:-
SCCP phones
SIP phones
FXS as SCCP
PRI T1
For this intergration they definitely need
voice service voip
qsig decode
h323
sip
registrar server
Putting all the config in is a blanket to catch any future
devices, links that may be added.
If all your CME phones are SIP and all calls in/out are to be via SIP
dial peers then you only need to add
voice service voip
sip
registrar server
Alex
11-09-2011 06:37 AM
Thanks Alex.
CME---------------------SIP-Trunk------------------------Nortel
Here is the infrastructure
CME = 172.16.16.5
Nortel PBX = 172.18.18.150
There is IP reachability between both the boxes.
I dont see the sample configuration(URL you referred) any SIP configuration where it points to Nortel IP except these commands
voice service voip
qsig decode
h323
sip
registrar server
I understood the Dial-peer pointing to the Nortel IP as 'Session Target' nothing more than this??
In Nortel I see these steps created
1) a rule created as SIP and pointing to CME IP as SIP Trunk
2) Allowed Codecs
3) negotiation allowed SIP - to - SIP
4) configuration for Dial-peer < pointing CME IP to reach extension 500 - 599 >
I am still lacking to understand the CME part for SIP
thanks
Anthony
11-09-2011 07:01 AM
Anthony
Basically this has turned on SIP
voice service voip
sip
registrar server
The dial peer below instructs that calls using this DP are SIP
dial-peer voice 2300 voip
description dial peer digital toward Nortel SIP
translation-profile incoming voip
destination-pattern 232.
rtp payload-type cisco-codec-fax-ind 98
rtp payload-type nte 96
voice-class codec 1
voice-class sip g729 annexb-all
session protocol sipv2
session target ipv4:172.30.11.100
session transport tcp
incoming called-number ....
dtmf-relay sip-notify
fax-relay ecm disable
no vad
There is not much more to the basics
Alex
