CME Sip-ua outbound calls problems with messagenet VOIP provider
_Mike_
Hi all,
I have an existing old cme 7.1 based on a UC540 with this topology connections:   cme____firewall____adslrouter___SIPprovider
Once bought the phone number, the provider has sent me the following parameters: URI, Password and SIP Server  (sip.messagenet.it:5061)
I configured a sip-ua profile to permit all my cisco phones to place voip calls via "messagenet" provider.
Doing tests with my CIPC softphone, I can receive calls configuring the command  "number 112 secondary 5406042832 no-reg primary" under the ephone-dn, but trying to make outbound calls I got always the fast busy tone.
What am I doing wrong, can anyone help me?
Here is my "debug ccsip messages" and the cme conf. in attach, thank you in advance.
035188: May 25 10:34:41.107: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:9347xxxxx9@sip.messagenet.it:5061 SIP/2.0
Date: Wed, 25 May 2016 10:34:41 GMT
Call-Info: <sip:192.168.2.254:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
From: "05xxxxxxx2" <sip:112@sip.messagenet.it>;tag=EDCEE9AC-26E6
Allow-Events: telephone-event
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Remote-Party-ID: "IFI Tests" <sip:112@192.168.2.254>;party=calling;screen=no;privacy=off
Cisco-Guid: 455890549-563810790-2880145261-787559590
Timestamp: 1464172481
Content-Length: 303
User-Agent: Cisco-SIPGateway/IOS-12.x
To: <sip:9347xxxxx9@sip.messagenet.it>
Contact: <sip:112@192.168.2.254:5060>
Expires: 180
Content-Disposition: session;handling=required
Content-Type: application/sdp
Call-ID: 1F5A5458-219B11E6-ABB0876D-2EF134A6@192.168.2.254
Via: SIP/2.0/UDP 192.168.2.254:5060;branch=z9hG4bK3E33B2040
CSeq: 101 INVITE
Max-Forwards: 70
v=0
o=CiscoSystemsSIP-GW-UserAgent 2357 9567 IN IP4 192.168.2.254
s=SIP Call
c=IN IP4 192.168.2.254
t=0 0
m=audio 18002 RTP/AVP 0 8 18 100
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
035189: May 25 10:34:41.131: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
To: <sip:9347xxxxx9@sip.messagenet.it>;tag=ac2f3091de46227321b1af258e10b75e-3c84
Via: SIP/2.0/UDP 192.168.2.254:5060;branch=z9hG4bK3E33B2040;rport=56043;received=79.58.183.41
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.messagenet.it", nonce="V0WA61dFf78BY5IQto2DBbbF2rNhKuIkCKrgqfvMxS4snvgPYozQYGCmlkOC", qop="auth"
Server: sip.messagenet.it SIP Proxy
Content-Length: 0
Warning: 392 212.97.59.76:5061 "Noisy feedback tells:  pid=24839 req_src_ip=79.58.183.41 req_src_port=56043 in_uri=sip:9347xxxxx9@sip.messagenet.it:5061 out_uri=sip:9347xxxxx9@sip.messagenet.it:5061 via_cnt==1"
035190: May 25 10:34:41.135: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:9347xxxxx9@sip.messagenet.it:5061 SIP/2.0
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
035191: May 25 10:34:41.135: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
Content-Length: 303
Proxy-Authorization: Digest username="5406042832",realm="sip.messagenet.it",uri="sip:9347xxxxx9@sip.messagenet.it:5061",response="bb7956866aec9477983c390c07e5d74a",nonce="V0WA61dFf78BY5IQto2DBbbF2rNhKuIkCKrgqfvMxS4snvgPYozQYGCmlkOC",cnonce="51E8C7B7",qop=auth,algorithm=md5,nc=00000001
Expires: 180
Via: SIP/2.0/UDP 192.168.2.254:5060;branch=z9hG4bK3E33C2583
CSeq: 102 INVITE
Max-Forwards: 70
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
035192: May 25 10:34:41.159: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Auth/From Username Matching Policy Failed
To: <sip:9347xxxxx9@sip.messagenet.it>;tag=98df93dff07c6bc0cd4e22344f9aa5a7.101e
Via: SIP/2.0/UDP 192.168.2.254:5060;branch=z9hG4bK3E33C2583;rport=56043;received=79.58.183.41
CSeq: 102 INVITE
Content-Length: 0
Warning: 392 212.97.59.76:5061 "Noisy feedback tells:  pid=24845 req_src_ip=79.58.183.41 req_src_port=56043 in_uri=sip:9347xxxxx9@sip.messagenet.it:5061 out_uri=sip:9347xxxxx9@sip.messagenet.it:5061 via_cnt==1"
035193: May 25 10:34:41.163: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
24 Replies 24
Deepak Mehta
Hey Mike,
One thing i can see clearly in the logs is authentication is failing.
Received:
SIP/2.0 403 Auth/From Username Matching Policy Failed>>>>>>>>>>>>
So may want to check with Service provider and confirm on the username.thanks
Thank you Deepak,
but maybe it's not a credentials problems because I tried the same credential with a softphone like X-Lite and and the calls works fine.
Vivek Batra
Please check the FROM field of INVITE message;
So you're sending '112' as calling party number. I guess you need to send correct DDI number provided by your provider. Please apply desired translation rules and confirm.
- Vivek
Thank you Vivek,
assuming the following info, will I need a translation rules for every internal extension?
Will I apply my rule under the dial-peer voip?
Are you able to provide me an example of trans.rule for 112?
Thanks again.
uc540#sh sip-ua register status
Line          peer           expires(sec)  registered   P-Associated-URI
0*                                1           73            no
101                               20001       82            no
102                               20002       83            no
103                               20003       83            no
104                               20004       80            no
105                               20005       83            no
106                               20006       80            no
107                               20007       80            no
108                               20008       80            no
109                               20009       81            no
110                               20010       78            no
111                               20011       81            no
301                               20013       81            no
302                               20014       81            no
303                               20015       81            no
5xxxxxx2                      20019       2340          yes
A50...                            20016       82            no
A51...                            20017       82            no
Yes, you can apply translations to outbound voip dial peer.
Can you please share the DDI numbers range provided by your provider?
- Vivek
Thank you, I have a single number (05431796482) and the URI is 5406042832
So if 05431796482 is the main number, apply translations to respective outbound dial peer which changes any number to 05431796482.
- Vivek
Can you provide the cli commands Vivek?
voice translation-rule 10
    rule 1 /.*/ /05431796482/
voice translation-profile 10
    translate calling 10
Then apply the following command to outbound dial peer;
translation-profile outgoing 10
- Vivek
Hi Vivek, sorry for the late, I've finally applied your suggestion configuring the translation rule but still not working, during a call always the fast busy tone is occuring. I share the new debug ccsip messages in attach,
have you any idea?
Thanks in advance.
Anyone can help to fix this problem?
Thx
Hi Mike,
Can you compare the SIP REGISTER sent by X-lite with what CME is sending to PSTN? You can collect packet capture using wireshark on PC.
It will be nice if you can share the capture with us so that we can check it as well. Start the capture before you register X-lite with provider.
Hi Mohit,
thank you for your help, in attach can find the SIP packet capture for X-Lite client.
Do you note something interesting comparing it with the cme logs?
Thanks again.
Nobody can help??
Thx
