04-10-2015 12:25 AM - edited 03-18-2019 11:29 AM
This is really driving me nuts. I am not an expert with Cisco IP Telephony.
I have two sites connected via VPN (Cyberoam Firewalls) and there is communication between two sites. (ping is working)
But the IP Phones can not call each other, Internal is working fine. Please help guys !
CME Routers - Cisco 2901
IP Phones - Cisco 7821
Overall Topology :
IP Phone ----->2901 Router----->Firewall------>ISP Router------->Internet<--------ISP Router<-------Firewall<-------2901 Router<-------IP Phone
Head-Office has extensions 1xxx
Branch Office has extensions 2xxx
There is NAT on the firewalls & ISP Routers on both the ends.
The firewall is configured to allow any packet
The configuration of the routers are as follows:
10.10.60.1 (Head Office CME Router)
version 15.4
hostname MEC-DOHA
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-3.M.bin
boot system flash:c2900-universalk9-mz.SPA.152-4.M6a.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$uKeq$kC2CxdrHFNaOkzTaZrS5o.
no aaa new-model
ip dhcp pool VOICE
network 10.10.60.0 255.255.255.0
default-router 10.10.60.1
dns-server 10.10.60.1 8.8.8.8
option 150 ip 10.10.60.1
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip cef
no ipv6 cef
trunk group MyTrunkGroup
cts logging verbose
voice-card 0
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g729r8
voice register global
mode cme
source-address 10.10.60.1 port 5060
max-dn 35
max-pool 25
timezone 31
create profile sync 0009353635334336
voice register dn 1
number 1001
pickup-group 33
voice register dn 2
number 1002
pickup-group 33
voice register dn 3
number 1003
pickup-group 33
voice register pool 1
busy-trigger-per-button 2
id mac E0D1.73E5.1FD0
type 7821
number 1 dn 1
voice register pool 2
id mac E0D1.73E5.209D
type 7821
number 1 dn 2
voice register pool 3
id mac E0D1.73E5.066C
type 7821
number 1 dn 3
license udi pid CISCO2901/K9 sn FCZ1842C394
hw-module pvdm 0/0
redundancy
ip tcp path-mtu-discovery
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description INTERFACE--WAN
ip address 10.10.10.1 255.255.255.0
ip nat enable
duplex auto
speed auto
description INTERFACE--LAN
ip address 10.10.60.1 255.255.255.0
ip nat enable
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.60.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.10.10.254
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 60 permit 10.10.60.0 0.0.0.255
control-plane
voice-port 0/0/0
trunk-group MyTrunkGroup 1
timeouts interdigit 5
connection plar opx 1010
caller-id enable
voice-port 0/0/1
trunk-group MyTrunkGroup 2
caller-id enable
voice-port 0/0/2
trunk-group MyTrunkGroup 3
caller-id enable
voice-port 0/0/3
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2000 voip
destination-pattern 2...
session protocol sipv2
session target ipv4:10.10.70.1
incoming called-number 1...
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1000 voip
destination-pattern 1...
session target ipv4:10.10.60.1
dial-peer voice 999 pots
trunkgroup MyTrunkGroup
description **EMERGENCY**
destination-pattern 999
forward-digits all
dial-peer voice 9999 pots
destination-pattern 9999
forward-digits 3
dial-peer voice 444 pots
description **LOCAL**
destination-pattern 94.......
forward-digits 8
dial-peer voice 333 pots
description **MOBILE**
destination-pattern 9[3-8].......
forward-digits 8
dial-peer voice 111 pots
description **INTERNATIONAL**
destination-pattern 9T
dial-peer voice 3000 voip
incoming called-number .
sip-ua
gatekeeper
shutdown
telephony-service
ip source-address 10.10.60.1 port 2000
no service local-directory
service dnis dir-lookup
max-conferences 8 gain -6
web admin system name admin secret 5 $1$8Q/7$wDybMpgoX1WUDELLPtD7O.
dn-webedit
time-webedit
transfer-system full-consult
directory entry 1 1002 name SALES
MEC-DOHA(config)#
10.10.70.1 (Branch Office CME Router)
version 15.4
hostname MEC_INDAREA
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.154-3.M.bin
boot system flash0:c2900-universalk9-mz.SPA.152-4.M6a.bin
boot-end-marker
enable secret 5 $1$nCg/$a2HoKk1R/V28iwwr/yOuy/
no aaa new-model
ip dhcp pool VOICE
network 10.10.70.0 255.255.255.0
default-router 10.10.70.1
dns-server 10.10.70.1 8.8.8.8
option 150 ip 10.10.70.1
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
voice rtp send-recv
voice service voip
sip
mode cme
source-address 10.10.70.1 port 5060
max-dn 35
max-pool 25
timezone 31
create profile sync 0006251728330142
voice register dn 1
number 2001
voice register dn 2
number 2002
voice register dn 3
number 2003
id mac E0D1.73E5.1F03
type 7821
number 1 dn 1
type 7821
number 1 dn 2
id mac E0D1.73E5.2085
type 7821
number 1 dn 3
license udi pid CISCO2901/K9 sn FCZ1842C39A
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$wDqb$jrxUG6abswL62ZlGdLhLO0
redundancy
no ip address
shutdown
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.20.1 255.255.255.0
duplex auto
speed auto
ip address 10.10.70.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.70.1
ip http server
ip http access-class 23
ip route 0.0.0.0 0.0.0.0 10.10.20.254
access-list 23 permit any
control-plane
voice-port 0/0/0
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
incoming called-number 2...
no vad
forward-digits all
forward-digits 3
forward-digits 8
forward-digits 8
gatekeeper
shutdown
telephony-service
max-ephones 10
max-dn 10
ip source-address 10.10.70.1 port 2000
create cnf-files version-stamp Jan 01 2002 00:00:00
MEC_INDAREA#
I hope to get some help
Solved! Go to Solution.
04-10-2015 02:44 AM
Gr8 to see you got it solved.
Additionally check the dial-peer going from HQ to BR is using SIP whereas H.323 viceversa. You can check if it's done purposefully.
Since you are not using any translation profiles while calling between sites, dial-peer 1000 in HQ and 2000 in RB seems of no use.
Vivek
04-10-2015 02:36 AM
Guys the problem has been solved, It was an issue from toll fraud application which was blocking the call.
Following commands were entered and it worked !!
Gw(Conf)# voice service voip
Gw(Conf)# no ip address trusted authenticate
04-10-2015 02:44 AM
Vivek
04-30-2015 02:11 AM
Thanks Vivek :)
04-30-2015 02:33 AM
You are most welcome!
