286
junaidkhan1991
Beginner
CME to CME
This is really driving me nuts. I am not an expert with Cisco IP Telephony.
I have two sites connected via VPN (Cyberoam Firewalls) and there is communication between two sites. (ping is working)
But the IP Phones can not call each other, Internal is working fine. Please help guys !
CME Routers - Cisco 2901
IP Phones - Cisco 7821
Overall Topology :
IP Phone ----->2901 Router----->Firewall------>ISP Router------->Internet<--------ISP Router<-------Firewall<-------2901 Router<-------IP Phone
Head-Office has extensions 1xxx
Branch Office has extensions 2xxx
There is NAT on the firewalls & ISP Routers on both the ends.
The firewall is configured to allow any packet
The configuration of the routers are as follows:
10.10.60.1 (Head Office CME Router)
version 15.4
hostname MEC-DOHA
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-3.M.bin
boot system flash:c2900-universalk9-mz.SPA.152-4.M6a.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$uKeq$kC2CxdrHFNaOkzTaZrS5o.
no aaa new-model
ip dhcp pool VOICE
 network 10.10.60.0 255.255.255.0
 default-router 10.10.60.1
 dns-server 10.10.60.1 8.8.8.8
 option 150 ip 10.10.60.1
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip cef
no ipv6 cef
trunk group MyTrunkGroup
cts logging verbose
voice-card 0
voice call send-alert
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  registrar server expires max 600 min 60
voice class codec 1
 codec preference 1 g729r8
voice register global
 mode  cme
 source-address 10.10.60.1 port 5060
 max-dn 35
 max-pool 25
 timezone 31
 create profile sync 0009353635334336
voice register dn  1
 number 1001
 pickup-group 33
voice register dn  2
 number 1002
 pickup-group 33
voice register dn  3
 number 1003
 pickup-group 33
voice register pool  1
 busy-trigger-per-button 2
 id mac E0D1.73E5.1FD0
 type 7821
 number 1 dn 1
voice register pool  2
 id mac E0D1.73E5.209D
 type 7821
 number 1 dn 2
voice register pool  3
 id mac E0D1.73E5.066C
 type 7821
 number 1 dn 3
license udi pid CISCO2901/K9 sn FCZ1842C394
hw-module pvdm 0/0
redundancy
ip tcp path-mtu-discovery
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description INTERFACE--WAN
 ip address 10.10.10.1 255.255.255.0
 ip nat enable
 duplex auto
 speed auto
 description INTERFACE--LAN
 ip address 10.10.60.1 255.255.255.0
 ip nat enable
 duplex auto
 speed auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.10.60.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.10.10.254
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 60 permit 10.10.60.0 0.0.0.255
control-plane
voice-port 0/0/0
 trunk-group MyTrunkGroup 1
 timeouts interdigit 5
 connection plar opx 1010
 caller-id enable
voice-port 0/0/1
 trunk-group MyTrunkGroup 2
 caller-id enable
voice-port 0/0/2
 trunk-group MyTrunkGroup 3
 caller-id enable
voice-port 0/0/3
 caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2000 voip
 destination-pattern 2...
 session protocol sipv2
 session target ipv4:10.10.70.1
 incoming called-number 1...
 dtmf-relay h245-alphanumeric
 codec g711ulaw
 no vad
dial-peer voice 1000 voip
 destination-pattern 1...
 session target ipv4:10.10.60.1
dial-peer voice 999 pots
 trunkgroup MyTrunkGroup
 description **EMERGENCY**
 destination-pattern 999
 forward-digits all
dial-peer voice 9999 pots
 destination-pattern 9999
 forward-digits 3
dial-peer voice 444 pots
 description **LOCAL**
 destination-pattern 94.......
 forward-digits 8
dial-peer voice 333 pots
 description **MOBILE**
 destination-pattern 9[3-8].......
 forward-digits 8
dial-peer voice 111 pots
 description **INTERNATIONAL**
 destination-pattern 9T
dial-peer voice 3000 voip
 incoming called-number .
sip-ua
gatekeeper
 shutdown
telephony-service
 ip source-address 10.10.60.1 port 2000
 no service local-directory
 service dnis dir-lookup
 max-conferences 8 gain -6
 web admin system name admin secret 5 $1$8Q/7$wDybMpgoX1WUDELLPtD7O.
 dn-webedit
 time-webedit
 transfer-system full-consult
 directory entry 1 1002 name SALES
MEC-DOHA(config)#
10.10.70.1 (Branch Office CME Router)
version 15.4
hostname MEC_INDAREA
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.154-3.M.bin
boot system flash0:c2900-universalk9-mz.SPA.152-4.M6a.bin
boot-end-marker
enable secret 5 $1$nCg/$a2HoKk1R/V28iwwr/yOuy/
no aaa new-model
ip dhcp pool VOICE
 network 10.10.70.0 255.255.255.0
 default-router 10.10.70.1
 dns-server 10.10.70.1 8.8.8.8
 option 150 ip 10.10.70.1
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
voice rtp send-recv
voice service voip
 sip
 mode  cme
 source-address 10.10.70.1 port 5060
 max-dn 35
 max-pool 25
 timezone 31
 create profile sync 0006251728330142
voice register dn  1
 number 2001
voice register dn  2
 number 2002
voice register dn  3
 number 2003
 id mac E0D1.73E5.1F03
 type 7821
 number 1 dn 1
 type 7821
 number 1 dn 2
 id mac E0D1.73E5.2085
 type 7821
 number 1 dn 3
license udi pid CISCO2901/K9 sn FCZ1842C39A
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$wDqb$jrxUG6abswL62ZlGdLhLO0
redundancy
 no ip address
 shutdown
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 10.10.20.1 255.255.255.0
 duplex auto
 speed auto
 ip address 10.10.70.1 255.255.255.0
 duplex auto
 speed auto
 h323-gateway voip bind srcaddr 10.10.70.1
ip http server
ip http access-class 23
ip route 0.0.0.0 0.0.0.0 10.10.20.254
access-list 23 permit any
control-plane
voice-port 0/0/0
 caller-id enable
voice-port 0/0/1
 caller-id enable
voice-port 0/0/2
 caller-id enable
voice-port 0/0/3
 caller-id enable
 incoming called-number 2...
 no vad
 forward-digits all
 forward-digits 3
 forward-digits 8
 forward-digits 8
gatekeeper
 shutdown
telephony-service
 max-ephones 10
 max-dn 10
 ip source-address 10.10.70.1 port 2000
 create cnf-files version-stamp Jan 01 2002 00:00:00
MEC_INDAREA#
I hope to get some help
1 ACCEPTED SOLUTION
Gr8 to see you got it solved.
Additionally check the dial-peer going from HQ to BR is using SIP whereas H.323 viceversa. You can check if it's done purposefully.
Since you are not using any translation profiles while calling between sites, dial-peer 1000 in HQ and 2000 in RB seems of no use.
Vivek
4 REPLIES 4
junaidkhan1991
Beginner
Guys the problem has been solved, It was an issue from toll fraud application which was blocking the call.
Following commands were entered and it worked !!
Gw(Conf)# voice service voip
Gw(Conf)# no ip address trusted authenticate
Vivek
Thanks Vivek :)
You are most welcome!
Create
Recognize Your Peers
Content for Community-Ad
