01-07-2013 10:34 PM - edited 03-16-2019 03:02 PM
For a small office setup with 70 users is cisco 2921 running Version 15.1(4)M4 an recommended option
How do we check which IP Phone model is supported with above version. We also got 5 pieces of Cisco Cius Tablet, can these be registered on CME
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
Hope to hear from experts
cheers
Joe
01-07-2013 11:16 PM
Hi Joe,
Looking at the CME / IOS compatibility matrix, I see that 15.1(4)M4 is CME 8.6:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Please refer to the following link which talks about the supported IP Phones for that version:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme86spc.htm.html
As for CIUS, it was initially on the roadmap for CME 9.1 onwards but since the CIUS feature was deprioritized, it will not be supported. Internal Defect ID: CSCua70084 (you wont be able to view it since it's internal).
HTH.
Harmit.
01-08-2013 12:24 AM
Hi Harmit
appreicate your reply
After downloading version 15.2(4)M on 2921 do we need to download separately the firmware for sccp or sip for needed IP Phone model. Roaming users with Iphone, BlackBerry can they register to CME and do cisco got phone apps for such scenario
cheers
Joe
01-08-2013 02:11 AM
Hi Joe,
You can use Cisco IP Communicator for mobile users. Yes, you would use seperate firmware for SCCP and SIP and would need to upload the files to the flash of the CME. As for blackberry, AFAIK, RIM-CME solution is currently available as a managed service solution only by selected Service Providers.
HTH. Please rate if helpful.
Harmit.
