CME Wizard problem
davieshuw
Hi.
I've been having trouble getting the CUE HTML wizard to log into CME.
i've reloaded a different IOS on in and GUI files, but to no avail.
Basically when I type in my CME ip address, username and password into the wizard, I get a connection refused, check your cme config message
Here's my config (abridged, taken out the stuff that we dont need here)
Any ideas why it doesnt work?
Current configuration : 9356 bytes
version 12.4
hostname
boot-start-marker
boot system flash c2801-ipvoicek9-mz.124-15.T5.bin
boot-end-marker
card type e1 0 2
logging buffered 51200 warnings
no aaa new-model
clock timezone GMT -8
clock summer-time GMT recurring
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
dot11 syslog
ip cef
ip dhcp relay information trust-all
ip dhcp use vrf connected
ip dhcp excluded-address 192.168.16.1 192.168.16.15
ip dhcp pool
network 192.168.16.0 255.255.255.0
default-router 192.168.16.1
option 150 ip 192.168.16.1
ip domain name yourdomain.com
stcapp ccm-group 1
stcapp feature access-code
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
voice hunt-group 1 parallel
voice translation-rule 1
username cisco privilege 15 secret 0 cisco
username cue privilege 15 secret 0 cue
archive
log config
hidekeys
controller E1 0/2/0
pri-group timeslots 1-8,16
interface Loopback0
ip address 192.168.150.1 255.255.255.252
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.16.1 255.255.255.0
duplex auto
speed auto
interface Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 192.168.150.2 255.255.255.252
service-module ip default-gateway 192.168.150.1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
no cdp enable
ip forward-protocol nd
ip route 192.168.150.2 255.255.255.255 Service-Engine0/0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
access-list 23 permit 192.168.16.0 0.0.0.255
control-plane
disable-eadi
voice-port 0/2/0:15
cptone GB
timeouts initial 5
timeouts interdigit 5
telephony-service
max-ephones 24
max-dn 88
ip source-address 192.168.16.1 port 2000
auto assign 10 to 27
auto assign 5 to 8 type anl
service dnis overlay
service dnis dir-lookup
system message
url services http://192.168.150.1/voiceview/common/login.do
url authentication http://192.168.150.1/voiceview/authentication/authenticate.o
cnf-file location flash:
time-zone 21
date-format dd-mm-yy
voicemail 600
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
line con 0
login local
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
scot-simmons
You will likely need to remove the access-class on the http server. Since your CUE module is on 192.168.150.0 network it is being blocked.
scot-simmons
Ah i was looking for that!! thanks alot man, that worked.
