I have problems with an expansion module in a CME 7915-24 version 8.6.
The firmware is loaded B015-1-0-4.
When pressed the button to access the second button, "key does not work."
I've checked the settings and ephone module is loaded as 7915-24.
any suggestions?
telephony-service
max-ephones 20
max-dn 31
ip source-address 10.10.10.1 port 2000
calling-number local
system message ITP
url directories
http://10.10.10.1/localdirectory
url services
http://10.10.10.1/voiceview/common/login.do
url authentication
http://10.10.10.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale ES load CME-locale-es_ES-Spanish-8.6.2.4.tar
network-locale ES
network-locale 1 ES
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7962 SCCP42.9-1-1SR1S.loads
load 6921 SCCP69xx.9-1-1-0.loads
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 9051
max-conferences 8 gain -6
moh music-on-hold.au
multicast moh 239.0.0.1 port 16580 route 10.10.10.1
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 0.........
secondary-dialtone 0
after-hours block pattern 1 000 7-24
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 15
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
max-calls-per-button 2
type 7962
ephone-template 16
type 6921
ephone-dn 1 dual-line
number 1001
pickup-group 100
label 1001
description name1
name name1
allow watch
call-forward noan 1002 timeout 25
ephone 1
device-security-mode none
description name1
mac-address 1234.1234.1234
ephone-template 15
username "name1" password 123456
blf-speed-dial 2 1001 label "name1"
blf-speed-dial 3 1002 label "name2"
blf-speed-dial 4 1003 label "name3"
blf-speed-dial 5 1004 label "name4"
blf-speed-dial 6 1005 label "name5"
blf-speed-dial 7 1006 label "name6"
blf-speed-dial 8 1007 label "name7"
blf-speed-dial 9 1008 label "name8"
blf-speed-dial 10 1009 label "name9"
blf-speed-dial 11 1010 label "name10"
blf-speed-dial 12 1011 label "name11"
blf-speed-dial 13 1012 label "name12"
blf-speed-dial 14 1013 label "name13"
blf-speed-dial 15 1014 label "name14"
blf-speed-dial 16 1015 label "name15"
blf-speed-dial 17 1016 label "name16"
blf-speed-dial 18 1017 label "name17"
blf-speed-dial 19 1018 label "name18"
blf-speed-dial 20 1019 label "name19"
type 7962 addon 1 7915-24
button 1:1
