06-19-2008 06:48 AM - edited 03-15-2019 11:23 AM
Can somebody help me to change keepalive messages for mgcp?
what it the command?
06-19-2008 08:37 AM
Which keepalive are you referring to, MGCP fallback?
06-19-2008 09:10 AM
Some times GW balancing between Publisher and Subscriber. As I suppose in this period PRI E1 goes down. This this problem of the network congestion. I purpose that I will increase keepalive mgcp packets I will mor flexible redundancy
06-19-2008 10:41 AM
Theis a hidden command in the current IOS but Cisco strongly recommend not to try this
command since this may cause some other problem.
The hidden command is
Mgcp timer keep-alive 25
