Communications Manager 7.x dependency flow chart
pstryer
Can anyone point me to a document or send me a document that is a flow chart or some kind of lay out of the dependency on Communication Manager 7.x.
For example you create a gateway before you create a Route Group because the Gatway is select from a the Route Group.
There are many dependencies on CUCM and I would like a flow chart or some list of them. Also if the flow chart or another chart out there of where different items are assigned. for example a partition can be put on a phone device and a line and all the other places a partition can be assigned on CUCM
Paul Stryer
Jaime Valencia
There really is nothing like that for each and every single thing.
Dial Plan
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.html
Shows the GW -> RG -> RL diagram.
But the rest of it is here:
Cisco Unified Communications Manager (CallManager)
Maintain and Operate Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
The admin guide shows what parameters can be configured under each page.
There is no shortcut for learning all this, it's hands on experience or plenty of documentation to put it all together in your head and understand what needs to be configured and in which order.
java
if this helps, please rate
java
