Compactability for Cisco IP Phones with Microsoft Lync 2013
nithin louis
We would like to know the compatibility of Cisco IP Phone models which can work with Microsoft Lync 2013.
Thanks in advance
Nithin....
You mean compatible, not compactable.
The only document about anything being tested and supported with Lync 2013 right now, is cucilync 9.2, nothing else as of now.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
Always review the RNs for that kind of questions
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucilync/9/RN/CUCI_BK_C4FE2D36_00_cisco-uc-integration-for-microsoft_chapter_00.html
java
java
Hi Java,
Thanks for your reply.
Please to inform you that I am  not integerating with CUCM with Lync 2013.
I want to know that Cisco IP Phones is compactable which can directly (as SIP Phones)connect to LYNC 2013?
Best Regards
Nithin Louis.
java
java
