08-26-2015 08:17 AM - edited 03-17-2019 04:06 AM
Hi, I have search a lot of documentation about compatibility between cisco SRST 881 gateway and cisco unified comunication manager 9.1.2, and i can not find any, if any body could help me with a link of any compatibility matrix if exists.
thank you for your help, regards!!
Solved! Go to Solution.
08-26-2015 01:56 PM
Also below user facing links confirms the same.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/versions/CCMtrix.html
JB
08-26-2015 01:53 PM
88X is supported for SRST
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/requirements/guide/srs10spc.html
i have validate the same in some CISCO internally discussion for you.
JB
08-26-2015 01:56 PM
JB
08-26-2015 02:07 PM
Hi Jitender,
I see your link and this is correct, I was installed the 15.2.3T1 and about voip it is worky properly, there is a bug for VPN but this bug was be since a lot of time ago and continue open, but dont care, it is not important.
thank you for your help, best regards Jitender.
08-26-2015 02:14 PM
Hi Luis,
Glad to help
JB
06-20-2018 09:15 AM
Link is about Contact Center Versions , not to CUCM Version, still validates 881V compatibility with CUCM 9.1(2) ?
