Compatible Headrests for IP Phones
angel-moon
Level 3
Level 3
Al,
does anyone have a suggestion for headrests that are compatible with the 7965 IP Phones?
Thanks in advance!  All replies rated.
5 Replies 5
Jing Hua
Hi Angel,
Although Cisco Systems performs limited internal  testing of third-party headsets for use with the Cisco Unified IP  Phones, Cisco does not certify or support products from headset (or  handset) vendors.A variety of headsets from leading headset  manufacturers have been reported to perform well with Cisco Unified IP  Phones. For details, contact the headset manufacturer.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_6/english/user_guide/75706545con.html#wpxref19042
But for your information  I am using "sennheiser" headset
Thanks for the replay Jing.  I am looking for the shoulder rests though, not headsets.  Thans for the effort
Angel,
Try this link
http://www.voiplink.com/Cushioned_Shoulder_Rest_Full_Length_Dark_Gray_p/shoulder-rest.htm
Alex
Regards, Alex. Please rate useful posts.
Oops, it must be the time for bed. Sorry for the wrong info Angel.
Rob Huffman
Hi Angel,
I believe the accessory you are looking for is called a "shoulder rest" if so,
some of our user have found these ones to be quite good;
http://www.amazon.com/Softalk-Products-Telephone-flat-back-Self-adhesive/dp/B004E2S6FG/ref=pd_sbs_op_6
I always encourage these users to move forward with an actual headset to help
ergonomically but some still prefer the "shoulder rest"
Cheers!
Rob
