Concurent call
iboboewfs
how do I know about how many concurent call I can run on an MPLS circut of 1.5 MB
what are the criteria to know the number of concurent calls
5 Replies 5
Jaime Valencia
Basically the codec will be the main thing here, you can use the BW calculator from CCO to do the math
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
where to get a BW calculator ? I have a CCO account.
the below link did not work.
please advise.
http://tools.cisco.com/Support/VBC/do/CodecCalc1.do
Or just search bandwidth calculator on CCO.
java
java
it does help.
but still how do I determine for a site of 6 users with a connection of 1.5 mb MPLS connection.
how many concurent call I can have at this location ?
Just do the math, once you know how much BW you'll need per call X number of calls = BW
Or in your case, assuming you want to use the whole BW on your MPLS,
1.5/BW per call = calls
java
java
